Question about Microwave Ovens
Panasonic 1200 W, model NN-T991SF, run for 4-5 seconds and stops regardless of the function used (defrost, heat, sensor, etc.) and sounds wierd. Thank you if you can help. HR
  • Anonymous Jun 03, 2008
    hugor001 has described my problem exactly. I was going to look for a service center. If there is a solution please let me know.
    thanks
    Ali
    nezhad@rogers.com
  • mkaplan660 Nov 24, 2008
    I have the identical porblem. One issue is that the unit is only rated for approx 1400 amps and I have had it checked - it is pulling 1900 amps which is dangerous! The wiriung in the house and the unit are not designed for this much current. Has anyone solved this porblem?
MicrowaveSvc
  • 9086 Answers
SOURCE: Panasonic NN-H664 1200 Watts Microwave
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job.
It's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
To order Panasonic parts see http://www.pasc.panasonic.com/epartr ; To download a Panasonic manual see
http://service.us.panasonic.com/operman ; to find an authorized Panasonic servicer, see
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 ; For FAQs, see http://service.us.panasonic.com/faq/faq.aspx
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
  • 579 Answers
SOURCE: panasonic microwave does not heat , but the rest seem's to work?
High voltage parts are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Jan 25, 2008
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: How do I remove the sensor inverter on the Panasonic NN-S96OWA ?
That's a misnomer.
And oven may have an inverter and it may have a sensor (usually either a heat sensor or humidity sensor).
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your exact symptoms, so we can help you troubleshoot the problem and make recommendations.
Posted on Jan 11, 2010
SOURCE: panasonic NN-CD997S microwave
i have microwave problems power trip when switch on the unit. please help me.
Posted on May 29, 2010
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
MY EMERSON MW1119B STOPPED HEATING
Sounds like it's broken. Go for Panasonic next time, they make better microwaves. Here's one I was looking at http://bestmicrowavereview.com/panasonic-nn-sn651b-genius-1-2-cuft-1200-watt-sensor-microwave-review/
Jan 04, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave stops mid cycle
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Dec 27, 2012 | Panasonic NN-T664SF Microwave Oven
Panasonic 1200 watt microwave oven model:NN-S561BF,year:May 2001.When trying to heat foods the unit runs for 5-10 seconds then stops,I don't sense any heat.Anyone have any common repair tips? as I have...
Wow you must have been a TV repair tech too. Salute!! They have gotten more safisticated but some things never change. The magnetrons are real reliable. If the unit runs for 5 to 10 seconds it sounds like a control issue. The only other possible problem could be a bad HV diode. The new units have the safistication to know when the magnetron is not working and would shut down. Certainly an easy and cheap fix. You seem to have the expertise to explore this. Let me know how it works out or if you need more info. Thanks for using FixYa.
hardrocko
Feb 11, 2010 | Panasonic Microwave Ovens
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Nov 19, 2008 | Panasonic NN-S443WF / NN-S443BF 1200 Watts...
Panasonic Microwave Oven Stops After 15 seconds - Never Heats
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Oct 21, 2008 | Microwave Ovens
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
Panasonic NN-H664
You can order Panasonic parts here.
Or you can contact your nearest Panasonic-authorized servicer.
Aug 08, 2008 | Panasonic NN-H664 Microwave Oven
Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
Microwave Ovens Logo
306 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
