Question about Dishwashers
Water is not coming out of the arms. - Dishwashers
    Scholar:
  • 58 Answers
Most likely a mineral build up
i recommend calling 1-800-253-1301 Whirlpool
purchasing part number 18001059 dishwasher magic
this product will remove build up
Posted on May 01, 2008
Why is the top spray arm not turning
All of the water coming to the upper spray arm comes through the feed tube. If the feed tube is blocked or the probe flapper is hung open, water will not flow properly to the upper spray arm. Be sure that when you push in the upper rack the manifold probe is in position in the feed tube. Try adding more water in the tub to see if the upper spray arm starts rotating. Other possibilities; low water charge, cracked spray arm & poor wash pump performance.
Jul 28, 2016 | Dishwashers
LG Dishwasher water flow is weak coming out of the lower spray arm. No water coming out of the upper spray arm. I changed the water inlet valve, and there isn't any difference.
There is a possibility the water pressure itself is low from the kitchen line or the dishwasher is set at incorrect water pressure setting and does not collect enough water based on the flow time of inlet valve. If you hear the wash motor cut in then there is not enough water in the base to start pumping it to through the arms.
Apr 11, 2014 | LG 24 in. LD-12BS6 Stainless Steel...
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
Frigidaire dishwashers arms are not moving
Make sure the water inlet valve is fully opening.
Jul 10, 2017 | Frigidaire 24 in. FDB1050RE Built-in...
Water jet arm does not work water goes into the dishwasher dishwasher drains but the arm does not work the dishes are not getting sprayed with hot water the dishes are not getting cleaned the soap in the...
In most units, the movement of the arm is powered by the water. If the water does not come out of the arms, check the filter for debris or the arm itself. This could also be caused by mechanical issues. You may want to inspect the arms itself for loose connections or worn out parts.
Oct 06, 2009 | Dishwashers
Sprayer arm is not spinning, water comes up through weakly.
your water supply is too low. he watervalve (inlet valve) may be clogged. With insufficent supply you get a low fill and not enough water to fully enage the pump's power.
Apr 08, 2009 | Dishwashers
Water coming out of bottom during run cycle
Your lower spray arm is broken, allowing the water the hit the door where it shouldn't thus causing the water to blow out of the door gasket. To remove you turn the center plastic screw in the middle of the spray arm clockwise while holding the spray arm stationary. You can obtain the spray arm either at you local appliance dealer or at repair clinic dot com.
Feb 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Figidare dishwasher
It seems other posts were correct - The upper arm doesn't spin all the time. Once I learned that, and let the dishwasher cycle through, I saw that the upper arm does spin. So, there wasn't a problem with the upper arm afterall. That doesn't solve my crusty dishes problem, but that may have something to do with the soap we're using. We're going to try changing that next.
Dec 27, 2008 | Dishwashers
Dishwasher
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher
if no water is coming into the machine at all it is a problem with the water valve, not your spray arms. as far as the spray arm goes I need the manufacture and model number to explain what to do.
Sep 24, 2007 | Dishwashers
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
