Can't center image on screen on my Nec MultiSync700 monitor.
  • 558 Answers
On the monitpor you can press the auto button
Posted on May 01, 2008
Image auto adjust
it seems the LCD panels is defective.
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 05, 2014 | NEC Office Equipment & Supplies
An 'etch-a-sketch' - type image that at quick glance, looks like an elephant, appears in the upper right section of the screen. It isn't captured with print screen. Swapped out monitors to different CPUs....
I did see a similar issue with a Gateway display, the source of the image was the screen is damaged by the cover inside the screen. Basically, the inside frame was scratching the back of the screen making the image to appear until it damages the screen enough to turn off pixels.
Another possible cause are: "burned pixels", some kind of damage (liquids inside the display), the display was hit, or something like that.
The only solution is to replace the display or use it until is breaks (but it will be quite annoying).
Mar 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Dell d600 will not transfer laptop screen image to nec projector
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and external DVI monitor simultaneously, and external DVI monitor only. HOpe this helps
Oct 22, 2009 | NEC VT460 Multimedia Projector
Screen off center
try updating the latest driver for your video and bios. try connecting your laptop to external monitor
if both of this didnt solve your problem, i suspected you lcd screen is faulty and need to replace.
May 29, 2009 | NEC MultiSync XE21 (White) 21 in.CRT...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Distorted shrunken picture
hi
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
cheers
pls rate if this was any help
Mar 31, 2009 | NEC MultiSync FE700 17" CRT Monitor
Nec MONITOR TURNS ON FOR A SEC THEN GOES BLACK
This monitor is going into the protection mode due to a component failure. The unit should be sent or taken in to a service center for testing and repair. The NEC customer support telephone number is 1-800-632-4662. The website for customer support is www.necdisplay.com/support center. They will be able to tell you where you can take you monitor for servicing. I hope this information helps you with you problem
Mar 05, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
DiamondPoint V71LCD Not displaying image
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Jun 27, 2007 | NEC-Mitsubishi Nec Display Solutions...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
