2001 GMC Yukon XL Logo
Posted on Aug 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air conditioner blows warm air sometimes then cold air sometimes. no noise from compressor, clutch working, and no leakes.
Anonymous
Level 2:
  • Expert 187 Answers
  • Posted on Sep 21, 2010
Anonymous
Expert
Level 2:
Answers
187
Questions
0
Helped
61006
Points
615
The system may be low on refrigerant, due to a leak, or possibly has a faulty low pressure sensor. If it cycles quickly, I would be lloking for a leak. If it only works randomly, but blows cold when working, possible low pressure switch issue. either way, the system should be checked with a qualified repair shop.
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Vacuum leak most likely, thus not operating air blend door.
My air conditioner is blowing warm air on the driver side and cold on the passenger side
see this steps and think with clearly and logically NOT feared. God bless you
checkmark.gif Start with the compressor. Does it engage when you turn on the A/C?
If so, the compressor is working and the A/C system probably contains enough refrigerant to make cold air, so the problem is inside the HVAC unit. Replace the motor that controls the blend air door (this is a difficult job and best left to a professional since it involves tearing apart the HVAC unit -- about an 8 to 10 hour job!).
If the compressor does not engage when you turn on the A/C, see if it will run by jumping the compressor clutch wire directly to the battery (use a fused jumper wire). If the compressor works when you jump it, and the A/C blows cold air, the system contains refrigerant and the fault is likely a bad A/C compressor clutch relay or a bad clutch cycling switch or pressure switch.
If the compressor does not engage when you jump it, the problem is a bad compressor clutch.
If the clutch engages but the compressor does not turn (the belt will start to slip and squeal), the compressor is locked up and you need a new compressor.
If the compressor clutch engages and turns the compressor, but the A/C still does not blow cold air, the system is probably low on refrigerant and needs to be recharged.
2helpful
AIR CONDITIONER
Could be a list of things including low on freon, low pressure switch, relay, or the a/c clutch on the compressor.
Problem with heating and air conditioning. The driver's side is blowing hot air and the passenger side is blowing cold air
Air Conditioner blows warm air
  1. Air conditioner system is discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  2. Air conditioner compressor clutch not engaging. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
My GMC Sierra's air conditioning works great but the driver side vents will spontaneousely start blasting out hot air. The passenger side continuse to blow cold air. If iI turn the truck off and...
No Cold Air Blowing out of vents Air conditioner just blows out warm/hot air only what would cause this it just happened very quickly went to to store Approx. 14 miles away from home went to leave to get...
There are a few possibilities. Blown fuse to the compressor clutch, bad clutch, seized compressor, broken belt, low system pressure, or a rock through the coils in front of the radiator causing a leak. Take it to a reputable mechanic for repairs.
3answers
2000 ford taurs a/c dont work it blows cold when i power up the compressor.its running 45 lbs on my gage on the low side.
Hi...
Perform the following basic Checks and Information
1. Check Drive Belts,If belt is intact proceed to the next step.
2. Check for Compressor Clutch Engagement - Turn the air conditioner to the "on" position and set controls to the coldest setting. Start the engine and allow to idle. Then open the hood and inspect the clutch at the front of the compressor, is it turning? "Engaged" if so, the system has enough refrigerant to activate. If the system is low on refrigerant it will not work properly. In this case an air conditioner recharge kit is needed to recharge the system. If the compressor clutch is not turning proceed to next step.
3. Inspect for Refrigerant Leaks
4. Check under dash panel and under hood power distribution center
5. Check Temperature Control Vents - The vents inside your car are controlled by a cable, electrical servo or vacuum servo. If the vent door is not functioning properly it will cause warm air from the heater to exit the vents. To check this start the car and allow the engine idle, next turn the blower motor speed on low, switch the temperature control from warm to cold while your ear is close to the vents. You should hear the door move inside the heater box as it swings from open to close. If not, inspect for a vacuum leak or a shorted motor in the servo, repair the leak or replace the servo motor.
Thanks
Smith
My air conditioner blows out warm air when I turn the dial all the way to cold. I just recently tried recharging the a/c but it made a hissing sound (it was what I just plugged in). I believe the a/c...
Sounds like you got a leak all right Check compressor clutch as well Motor revs should fluctuate when compressor cuts in and out Could be the seals in the compressor as well You need to find where the hissing noise is coming from
AC not blowing cold air at times
poss causes are, sticking low pressure switch, defective Ac compressor clutch closing coil or incorrect clutch driven plate air gap, spec is 0.26 thousands.
1helpful
Ac works some times
HI. Here is a complete check list that will help you trouble shot thsi issue. You will find the problem in one or more of these areas stated below.
1. Check Drive Belts - The air conditioner utilizes a drive belt that supplies power to rotate the compressor, which is basically a refrigerant pump. If the belt fails the compressor has nothing to drive it, inspect and replace as needed to restore operation. If belt is intact proceed to the next step.
2. Check for Compressor Clutch Engagement - Turn the air conditioner to the "on" position and set controls to the coldest setting. Start the engine and allow to idle. Then open the hood and inspect the clutch at the front of the compressor, is it turning? "Engaged" if so, the system has enough refrigerant to activate. If the system is low on refrigerant it will not work properly. In this case an air conditioner recharge kit is needed to recharge the system. If the system is low on refrigerant it could cycle on and off, making a ticking noise. If the compressor clutch is not turning proceed to next step.
3. Inspect for Refrigerant Leaks - If the system has a large leak and no refrigerant remains it will not activate. First test system for a static pressure charge, with the engine off attach an ac gauge to the low side pressure port and check the state of charge. Depending on outside temperature there should be between 50 psi and 80 psi. (Cool and warm). A refrigerant leak detector is needed to inspect for leak, but if you do not have a leak detector there is an alternative method. The air conditioner system is designed to run with oil suspended in the refrigerant to lubricate the system. Check for oily residue outside the system by inspecting all hoses, compressor, condenser, evaporator or receiver drier and replace any component that has failed.
4. Inspect Fuses - Check under dash panel and under hood power distribution center. Replace failed fuses as needed, recheck system. If the new fuse fails when reinstalled a short circuit is present and requires diagnosing with a wiring schematic, follow circuits to locate short, repair as needed and recheck system.
5. Check Temperature Control Vents - The vents inside your car are controlled by a cable, electrical servo or vacuum servo. If the temperature blend door is not functioning properly it will cause warm air from the heater to exit the vents. To check this start the car and allow the engine idle, next turn the blower motor speed on low, switch the temperature control from warm to cold while your ear is close to the vents. You should hear the door move inside the heater box as it swings from open to close. If not, insect for a vacuum leak or a shorted motor in the servo, repair the leak or replace the servo motor...
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
