Question about Asrock P4I45GV R5 Motherboard
Always f2 i'll try to configure in cmos but when i save and exit it does not save...coz its always f2 and the message display is wrong cmos setting....the last time i did was.i'll try to upgrade the memory from ddr 333 to pc 3200.my bord is asrock p4ip45gv rev.5.0 and intel cel D 2.26ghz/256/533.what should i do...
Maybe you have put a jumper in your cmos..
Posted on May 14, 2008
    Genius:
  • 1,027 Answers
If the cmos wont save you may have to change the cmos battery,the little button cell also check to see if the jumper for cmos is in the correct position.
Posted on May 01, 2008
    Problem Solver:
  • 10 Answers
If I understand correctly your saying when you exit the cmos, id doesn't save your changes. Make sure when you exit you select the option to save and exit. If that doesn't work, your cmos battery is dead. Look in the mobo manual to find out what replacement battery you need.
Harris
When i updat bios the bios sating are not save
Press F10 and make sure to save changes and exit. Do not select exit without saving changes. If this does not work, you might have to replace the CMOS battery. If the CMOS battery is below 3V, it is bad and will not save any changes. It will always boot to the default/factory settings.
Dec 02, 2011 | HP Compaq Presario SR1620NX...
As i turned on the monitor the screen shows CMOS WRONG PRESS F1 TO SETUP PRESS F2 TO LAOD DEFAULT VALUE
hi,
first of all check the main battery back of ur machine by unplugging from the mains power supply. if machine shuts off, then u have to replace the battery.and then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
if the main back up battery is ok, then another possibility is the CMOS backup battery of ur machine have some problem. that's why it loosed all the seted parameters. then u have to replace the CMOS battery of ur machine. normally 3V battery. then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
ok
Jan 13, 2011 | Dmm UT4000F Multi-Parameter Patient...
Good day. I have a Gateway m-1625 (reconditioned). About 5 months ago it started to give problems when booting up. When powered on the hard drive would be engaged & then it would shut off. After...
check the BIOS version, if there is an update for it on the gateway site apply it. a checksum error in CMOS BIOS cannot be overcome and you will always have to deal with this issue if no bios updates are available. There is a slim chance that you can revert back to an earlier version.
Mar 07, 2017 | Gateway M-1625 Notebook
Cmos
You need to press F1 and go into the BIOS to setup and detect everything. You will need to set the date, verify it detects your hard drive and memory, and enable/disable items as you need for your system.
Once it looks good, do a Save and Exit.
Jan 16, 2009 | Computers & Internet
Boot problem
Updating the BIOS could be the solution, but, let's leave that until last - if you get it wrong, you'll stuff up your machine (mobo) for good.
Don't worry about the CMOS jumper, it is there to clear the CMOS memory, but I don't think you need to do that.
Can you get into your BIOS during start up OK? (usually by hitting F8, F2, Del one of these keys or similar during start up, it should tell you which).
If you can navigate your way through the BIOS settings ok, don't change anything you're not familiar with - another place you can do damage, and somewhere towards the end, where you have to option to exit BIOS with or without saving there should be another option like "Reset Defaults" or "Load Optimal Settings" or "Set Last best Settings" or something like that.
Click on this then exit your BIOS. Your computer should restart.
Make sure your new memory battery you put in is up the right way, if it's upside down it could be causing a short - the usual way is positive up, that's the whole flat face with the writing on it - the insulated button side is negative (down).
**.The best way to acknowledge contribution is to rate it's relevance.**
Sep 07, 2008 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Boot problems
hi friend
Keep pressing F2 or del soon as you start up your PC u have to go in cmos setup by perssing f2 or del key when windows stat then press it there was option in go in boot there is boot device pryority set there cd dvd rom by press f10 to save cmos settings & exit then after pc was reboot u will able to boot from cd
Apr 11, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Unable to log in hp compaq persario laptop
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Nov 16, 2007 | HP Compaq Presario R4000 Notebook
Big problems
start the system hit delete or F2 to enter setup load system defaults then exit saving changes.
if it didnt work
Nov 16, 2007 | Acer Aspire 3000 Notebook
Asrock P4I45GV R5 Motherboard Logo
242 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
