Unit is 3 years old. On switching on "self check" is displayed for a few seconds, then display reverts to time for a few seconds then goes back to "self check" again and so on. Unit will not switch off with either remote or
unit switch, and drawer will not respond to "open" switch. If mains is disconnected then reconnected same sequence of events occurs.
Hi
Unfortunately, this is a common fault with these units.
Fortunately though, it can be fixed.
See my earlier solution show below.......
Ok guys, you asked for a fix for the DMR E55 Self Checking cycle. Here goes.
In 99% of cases this is caused by a faulty regulator on the main power board.
The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance.
Because of this it usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers.
Disconnect your DMR E55 from the power source and remove the lid. Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet.
Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
Next, using your soldering iron, remove what's left of the pins from the printed board and with a solder ****** or desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
Use a little heatsink compound on the back of your new regulator, poke the pins through the circuit board and then secure it to the heatsink. I usually fit an extra heatsink on these units which helps to reduce heat and prolong the life of the new component.
Next, resolder the 5 pins on the print side of the board. Use a magnifying glass and make sure you haven't missed anything or bridged connections in error and caused short circuits.
Now put the board back. This can be a little tricky but it's easy enough if you take care. Refit all the screws and carefully reconnect the multi connector.
If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, Your DMR E55 will no longer repeatedly self check and will operate correctly.
Whilst it saddens me to hear that some of you guys would toss your DMR E55s into the trash can for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail. good luck...
Posted on May 03, 2008
Nov 26, 2011 | Timex T309TT Clock Radio
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
Mar 29, 2011 | Dymo DateMark Date/Time Stamper
Oct 30, 2010 | Toyota Tundra Cars & Trucks
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
May 25, 2009 | 2002 Ford Windstar Cargo
Mar 06, 2009 | Pioneer Premier DEH-P960MP CD Player
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
Nov 05, 2007 | Dymo DateMark Date/Time Stamper
793 people viewed this question
Many thanks for this very explicit solution. I will replace the regulator and let you know the outcome. Regards, Azzet
I have the same problem with a DMR-ES20D machine. Is it the same STRG6353 voltage regulator / power supply board? The voltage regulator is IC 1150 and has 80455 written on it.
hi, my DVDR got the same problem and stuck in self check mpde and doesn't oprate, thanks
