Computers & Internet Logo
Posted on May 01, 2008
To unlock files
Hey,
i would like to know how to unlock my locked files specially those files in my registry being locked by certain spywares or viruses.
pls. give me how to sold this kind of problem. tnx
peter
InduSekhar Nandy
Level 1:
  • Contributor 1 Answer
  • Posted on May 01, 2008
InduSekhar Nandy
Contributor
Level 1:
Answers
Questions
0
Helped
59
Points
You Should Try Regrun Software
Tally error code 407 system error code11001 how to solve this problam
PROBLEM: Error Code 11001 In Tally is usually caused by misconfigured system files that create registry errors within your operating system. Windows errors can cause program lock-ups, slow PC performance, system crashes, computer freezing and more. CAUSE: Registry errors generally occur when new programs are installed over old ones without the old programs being completely uninstalled. This can cause registry pile-ups and error messages. Another potential cause of these error messages can come from malicious software such as adware, spyware, and viruses.
SOLUTIONS: Scan and repair any missing or damaged Windows registry files using RegCure Pro. After the registry issues are resolved, it is recommended to optimize your PC by removing any spyware, adware and viruses with SpyHunter.
SOLUTION 1: Automatically Fix Error Code 11001 In Tally with RegCure Pro
SOLUTION 2: Optimize your PC with SpyHunter.
SOLUTION 3: Manual Uninstall (Usually Solutions 1 and 2 fix this part automatically)
Abusript instalation could not open registry
It wasn't started with administrative rights. If this is in windows 7, 8, or 10, right click and run the installer with administrative rights. If the program still can't access the registry, it is likely that a registry file it requires is locked down by a security program (anti-virus, anti-rootkit, anti-spyware, anti-adware, anti-malware). Try disabling these programs before installing.
Tally error 11001
http://freefastercomputer.com/downloadregcure.php
http://freefastercomputer.com/downloadspyhunter.php
2helpful
4answers
My PC seems to be running slow, hangs up/locks up on all sorts of various apps. I run defrag and clean-up once a week. What can I do to get it to run smoother?
Some programs I run on mine to optimize performance are Glarys Utilities (helps cleanup old registry entries, temp internet files) and it also finds spyware issues. I also use Malwarebytes (When I know I have some spyware/adware on my PC)...In the past I've used CCleaner (also cleans up registry and temp files). **These are all free, BTW** If you know you have a bunch of junk that you don't use on your computer, get rid of it in the control panel-->add/remove programs. If you do remove a program be sure to run Glarys Utilites to get rid of those lost reg entries and old shortcuts. Hope this helps
http://download.cnet.com/Glary-Utilities/3000-2094_4-10508531.html
http://www.malwarebytes.org/
http://www.piriform.com/ccleaner
3answers
Help reemoving antivirus 2009
Generall the symptoms of spywares can be located on 2 places:
1. annoying pop-ups from the Right side bottom of screen next to the time, stating that you have certain number of
spywares, virus or errors. E.g of known spywares are spyware gaurd antivirus-2008,2009,2010, Vista antivirus or MS
pro and the list has no end..
2. your browser is giving you alot of annoying advertisements and spyware messages.
As these infections cannot be removed by any known security softwares some tools mentioned below can resolve these
issues with 97% success rate.
How to run these tools is pretty easy, please follow the steps I have mentioned below as per the tools.
Spyware Problems:
Tool No 1: SmitfraudFix: http://tinyurl.com/27wn7w
Download this tool from the mentioned link and Click RUN.. then click Open.. it start loading the tool...
Press any key to continue... on the screen you will have 5 options... Press option 2.. for registry cleaning press
Y if it prompts you and than option 3 & 5.. follow on screen easy instructions. Restart if it prompts you to do so.
Tool No 2: Malaware Bytes: http://tinyurl.com/6dtjrl
Download this tool from the mentioned above link and Click RUN, than Click Open.. Setup will install it.. It will
givee you option to scan (Quick or Complete).. Choose QUICK scan... once the scan is complete click show results..
Remove all infections and restart the PC.
Tool No 3: Hijackthis: http://tinyurl.com/25z5fa
This tool is made to specially take care of infections from IE. Run this tool from the link and Install.. Click do
a system scan only... Check all the options start with ...A)Toolbar B)BHO C)DPF D)Extras
PLEASE DO NOT CHECK ANYOTHER ITEMS UNLESS YOU ARE SURE ABOUT THE INFECTED FILE NAME.
RESTART YOUR COMPUTER...
RUNNING THESE TOOLS WILL TAKE CARE OF ALL THE SPYWARE OR VIRUS INFECTIONS.
Disclaimer: All these tools are thirdparty tools developed for helping people to get rid of spyware & viruses
effectively & Free. Nobody is responsible for any data loss.
5answers
How to remove manually Malwarrior rootkit malaware please help
Sir,
Manual removal of any spyware can be difficult. When you try to manually remove MalWarrior 2007, you risk destroying your PC. It’s highly recommended you use an automatic spyware scanner to determine you’re infected with MalWarrior 2007. It’s also recommended you backup your system any time before editing your registry.
Your Windows registry is the core of your Windows operating system, storing information about user settings, system preferences, and software, including which applications automatically launch at start up. Because of this, spyware, malware, and adware will often bury their own files into your Windows registry so that they automatically launch every time your start up your PC.
Because your registry is such a key piece of your Windows system, you should always backup your registry before you make any changes to it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or registry value, there’s a chance you may need to reinstall your entire Windows operating system. Make sure your backup your registry before editing it.
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any MalWarrior 2007 registry keys, select “Edit,” then select “Find,” and in the search bar type any of MalWarrior 2007’s registry keys.
  4. As soon as MalWarrior 2007 registry key appears, you can delete the MalWarrior 2007 registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
Computer acting funny after you’ve edited your registry and deleted MalWarrior 2007 registry keys? Just restore your registry with your backup.
How to remove MalWarrior 2007 DLL files: Like most any software, spyware, adware, and malware may also use DLL files. DLL is short for “dynamically linked library,” and MalWarrior 2007 DLL files, like other DLLs, carryout predetermined tasks. To manually delete MalWarrior 2007 DLL files, you’ll use Regsver32, a Windows tool designed to help you remove DLL and other files.
  1. First you’ll locate MalWarrior 2007 DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the MalWarrior 2007 DLL file is located. If you’re not sure if the MalWarrior 2007 DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the MalWarrior 2007 DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore MalWarrior 2007 DLL file you removed, enter “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Thanks
Good Luck
"Don't forget to rate the solution"
Ga k8n ultra sli keeps locking my computer up
Maybe the problem is not in the hardware, maybe your system is infected by the spyware virus. Try to download pctools spyware and pctools registry mechanic it's good anti spyware and registry checker. Clean first the spyware and run the registry mechanic to fixed the damage registry that cause of hanging of your computer.
3answers
Spyware
I would try running one of the free online scans by someone like Mcafee or PCCillin, you can run these without actually buying the software. They will help you see if you have any issues.
As for the file you cannot delete. It is likely that this file has been locked hence your not able to remove it. There is a free handy program called unlocker that may help if you search for this on google and install it, you can then right click on the file and you will have a new unlocker option, choose this and you can then unlock the file, and even try and delete the file from this program.
Hope this helps. Please note I have no idea what your file it so I cant guarantee that if you remove this file everything will still work, as long as your sure its ok to delete the method above should work.
Thanks
Simon
Grand Canyon Tech
Grand Canyon Tech
