No display when starting up - Computers & Internet
    Genius:
  • 2,785 Answers
I am assuming that even your bios does not come, plz resit the ram,if the problem persists than your video adapter is dead,send the mother board for repair
Posted on May 01, 2008
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
Canon_fax_b820_error_342
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If your problem not solved replace the SCNT PCB
May 01, 2011 | Canon FAX-B820 Plain Paper Bubblejet
Mi da errore ##331 .... dopo aver cambiato le cartucce . prima mi dava errore ##342 ... e non mi prende la carta . ho il fax canon b 140 AIUTATEMI Grazie mille
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If problem not solved replace SCNT PCB.
May 01, 2011 | Canon FAX-B840 Plain Paper Bubblejet
I am getting a CE error, what does that mean? Bill
4. Troubleshooting
4-2
4-2. Service Inspection Mode
- Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
- You can change the mode by pressing the Normal key. Each time the Normal key is pressed, the mode changes in the order of t1 → t2 → t3 → t4 → t5 → t6 → t7 → t8.
- If you want to activate a mode while operating the dishwasher, the door must be closed (The Door switches are ON.)
- If an "oE", "LE" or "tE1" error occur, make sure to enter Service Inspection Mode after resolving it.
- Service Inspection Mode is described in the following table.
Mode Related parts Symptoms Note
t1
Inlet Valve
Flow Meter
Low Level Sensor
4E
9E
If you press the Delay Start key, water is drained for 45 seconds and then the water supply starts.
If the pulse count is more than 660, change the mode.
Make sure to change the mode when the pulse count is more than 660 in t1 mode.
t2 Circulation Motor A nozzle does not inject
water.
1. Press the Delay Start key to start or stop the Circulation Motor.
2. If a low water level is detected, water is supplied again and the operation continues.
t3
Circulation Motor
Heater
Thermistor
HE
1. Press the Delay Start key to start or stop the heater and the circulation Motor.
2. If a low water level is sensed, water is supplied again and the operation continues.
3. The current temperature is shown on the display.
4. If the water temperature is more than 70ºC, the Heater does not operate.
t4 Fan Motor The Fan Motor does not
operate. Press the Delay Start key to start or stop the Fan Motor.
t5 Drain Pump
Low Level Sensor 5E 1. Press the Delay Start key to start the 2 parts.
2. When draining is finished, "t5" is blinking on the Display LED.
t6 Low Level Sensor
When the Micro Switch
is turned on/off, there is
no change on the display
or a symbol other than
On/OFF is displayed.
1. MICRO SWITCH On
→ The sensing state is displayed as 'On' on the 88 segment display.
2. MICRO SWITCH Off
→ The sensing state is displayed as 'OFF' on the 88 segment display.
t7 Thermistor There is no change in the
water temperature. The current temperature is displayed.
t8
Half Load Position of
Distributor Motor
Micro Switch
(DMR77 Model)
PE
1. If you press the Delay Start key, the parts operate just once.
2. There is no stop function.
3. While the Distributor Motor is operating, its sensing state is displayed as On/OFF on the 88 segment display.
4. When the Distributor Motor stops, the sensing state (On/OFF) of the Micro Switch is displayed.
Caution
If it has the power problem, you must check the FUSE first.
This dishwasher has the FUSE upon the Base. Refer to the 4-10 page.TRY THESE STEPS AND SEE WHAT HAPPENS THERE IS NO CE FAULT CODE LISTED IN THE MANUAL
Dec 12, 2010 | Samsung DMR78AHS Builtin Dishwasher
In my syatem, start with no display after windows
start windows in vga mode by pressing F8 at starting after POST. then set the resolution of your screen to 800X600 and restart.
Dec 21, 2009 | Intel DG31PR Motherboard
I need to find someplace to download the instructions, since mine didn't come with any
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
Apr 17, 2009 | Watches
Clock problem
try holding hte clock/set start button in for 3-5 secs, it sounds as if youve accidently turned of the clock display. .. a common issue especially after turning clocks back.. its a built in feature for people with too many clocks in kitchen, they allow you to turn off the display.
Nov 04, 2008 | KitchenAid KERC507 Electric Kitchen Range
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
