Question about Compaq Presario X1000 Notebook
LCD Screen ib very, very dark... does not light.
This is form an old post....
So once you think windows has loaded, under a bright light see if you can actually see your desktop, albeit very dark. Inverters can be sourced in US at around $20-50 so not too bad.
Exactly what is wrong with mine.
How do I get an "inverter" and is this something the average person can repair?
  • dennis1188 May 01, 2008
    THANK YOU!!!
    Problem Solver:
  • 7 Answers
You have one of two problems. Either your inverter has gone bad or your backlight is burned out. You can find both items as well as instructions on how to replace each from
Posted on May 01, 2008
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Ok million dollar question , i have a jvc lt-47x788
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Can you, and ready to spend $10, at least? Nobody here want a Million dollars. All of us know you haven't even dream that amount.
Jul 15, 2017 | LG 42LB4D 42 in. LCD HDTV
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 06, 2011 | Computers & Internet
Laptop screen goes dark while loadin windows
If you can see everything when you shine a light on it, it's most likely a 'backlight' going bad. These are somewhat easily repaired, but can be expensive. Good luck!
Apr 18, 2009 | Microsoft Windows Vista Ultimate Edition
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
adjust the brightness of the screen may u hav accidently turned to zero brightness.
if this doesnt solve then let me know.
May 01, 2008 | Compaq Presario X1000 Notebook
The Screen is Dark and Cannot be Bright by the Brightness Keys. It Flickers when it first comes on but goes Dark. Can see it if you shine a Flashlight on the Screen. Also the Lid Switch if you Press that...
Assuming all of the connections are secure this is most likely due to a failing LCD inverter which is basically the backlight of the screen. If it's less than a year old cash in on the manufacturer's warranty. If it's not you might as well buy a new one. Hope this helps.
Apr 13, 2008 | Computers & Internet
Screen went dark (almost completely)
check your power cord and make sure it's plugged in all the way, and if it is, check your brightness setting.
Usually it's the Fn key + an arrow key. Make sure the brightness is up all the way
Dec 12, 2007 | Dell Inspiron 6000 Notebook
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Compaq Presario X1000 Notebook Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
