Question about Vacuums
When I vacum the pool which position of the pomp need to be:filter? waiste,or backwash?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=561980
Generic problem for all Vacuums
When I vacuum the pool
Posted by lovepuppies3 on May 01, 2008
When I vacuum the pool which position of the pomp need to be: filter, waste, or backwash?
This is not a question for the vacuum website, and I suggest that you check with an actual pool company because a vac dealer would not know the answer to the question, only a pool company would know. Sorry I could not help you this time.
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 01, 2008
The suction in my vacum is not good. I changed
Depending on the type of vaccuum you may have another filter. I have a hoover and there is the hepa filter and another filter under the dirt container. If thats not the case, try taking off the entire hose and shaking it around. There may be stuff crammed in there. If one thing gets stuck, then everything else sticks to that. I had the same problem and when I took off the hose and shook it, a bunch of nails fell out (remodeling) and it worked fine after that.
Aug 19, 2009 | Vacuums
HEPA FILTER REMOVAL
the filter should be easily accessable on the right side of the vacum cleaner if it's facing you. at the base of the vacum there is a large round cover that is removable and behind it it the filter. generally you dont need to replace it. its a big round spunge that you could rinse with water and squeeze out until it's clean. you also need to rinse the filter cover which is like a plastic netting. let it dry for 24 hours and you should be good to go!
enjoy!
Aug 10, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Bissell turbo revolution
you can wash that sponge filter by hand but you must let it dry compleatly before putting it back in the machine, I found a filter pack for the lift off vacume at walmart, make sure teh bottom filter is clean as well. the lift off vacume has 3 filters there is one filter in the tray under the dirt cup, one in the top cup, and the hepa filter in the back the 2 foam filters must be clean or you can have reduced suction, the lift off vacume I have I found thrown away because they never cleaned it outthe brush was dirty and full of strings the belt was worn, the hose under the vacume was full and stopped up the hose in the back was compleatly stopped up all filters were compleatly clogged, and the hepa filter was missing entirely. Not to insult you or anyone but i've found that a lot of people are jsut to lazy to clean their vacume out it fills up with dirt they throw it away and get a new one, i've gottten many like new vacumes for this reason, this bissell is working like brand new now. and I just replaced the belt and all filters in it saving me approx. 150.00 for a new one
Dec 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacume Overheating
There will be a filter between the cylinder/bag and the engine. If your vacuum has a HEPA filter there will be one on the other side of the engine. Remove both of these and clean them out with water, allow to dry and replace.
Jun 18, 2008 | AEG Vacuums
How to connect the vacuum system in the swwiming pool
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564116
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Spin vacum won't suck up water
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter. Or the lid is not locked down all the way.
Dec 15, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Dyson DC07, too much suction...?
sounds like one of the filters is either damaged IE a hole or tear or is not seated correctly
Jun 09, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
128 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
