Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso Washer
Our Kenmore Elite Calypso Washer is either showing LD error or stuck in running mode without actually running. I suspect there is a clogging issue since my mother-in-law washed something that felt away during the wash it might have clogged drain. The washer is full of water. How do I fix this problem?
Thank you.
  • tday4me Jul 28, 2008
    My washer keeps starting and stopping. It's trying to continue but keeps shutting down. I had a repairman out to look at it and of course it wouldn't do it then. He said everything was fine! He looked 18 and had never even seen one of these machines before. 10 minutes later, the machine won't run.
  • ouaffai Jul 31, 2008
    my washer displays FL code and full of water and beeps , but it wont rinse or spin what can I do to fix this.
What is the error code ob
Posted on Aug 12, 2012
Set it on fire within the Sears store that you bought it from
Posted on Jul 15, 2008
  • 91 Answers
It seems the Kenmore Elite Calypso is prone to this kind of problem.
This link
will take you to a solution that was documented here on two years ago.
Don't forget to rate this solution once you've tried it !
Good Luck.
Posted on May 01, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My kenmore elite calypso has a code of ld
Well error Ld means - Long drain - The Ld error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. Anyway you can please check out the following steps -
Is the drain hose kinked or clogged?
Check the drain pump for clogs. Is it running?
Is the drain hose height greater than 95 inches?
Is the pressure switch hose connection from the tub to the machine control board pinched or plugged?
Do you see excessive suds in the basket? Are you using high efficiency (HE) detergent?
You can try to reset your washer by Pressing STOP/CANCEL. Please check out all the above steps, post comments if further you have the same problem.......
Good Luck!!
May 12, 2010 | Washing Machines
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
See page 17.
Sep 15, 2009 | Washing Machines
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
I have the Kenmore elite calypso washer and it stops and displays LD. What does this maean and how do i fix it? Thanks!
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 24, 2009 | Kenmore 2295x Top Load Washer
Kenmore (Calypso) Elite Washing machine shows LD and LF!
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Dec 10, 2008 | Kenmore Elite 21086
Kenmore calypso washer
LD is an error code for 'Long Drain'. The water pump may be clogged, there may be a clog under the washplate where the water exits the tub or a clog at the check valve. The best place to start is the water pump.
Jul 12, 2008 | Kenmore 20172 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
2,077 people viewed this question
Dan Webster
Dan Webster
Sal De
