How to set the security lock in laptop - Computers & Internet
    Genius:
  • 1,142 Answers
Plz specify the model and make
and also specify if it is a physical lock or the lock on your windows
Posted on May 01, 2008
    President:
  • 1,257 Answers
First of all you have to enter the bios ,to enter bios you must know the key to enter in your computer bios..every brand has its own key to enter for ex. f10 in compaq .so see user manual to enter bios when computer starts...in many system it enters by pressing del key in the keyboard.......now when you enters the bios ,you will see option set password just enter password you like and enter the same password once again for confirmation.............
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Posted on May 02, 2008
My x-tigis1501 forgotten password
Go into Settings and then Security. Select Clear Security Credentials. Now try again to set up a new password lock. If you are still getting interference then put your phone into Recovery Mode and select Wipe Cache Partition and Clear Dalvik Cache. You may not be exiting the application properly or missing a step to save your password. Since you are experiencing problems with the lock function it may be best to avoid it completely.
Dec 07, 2016 | Computers & Internet
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
Sep 13, 2013 | Computers & Internet
Compaqnx6120 my laptop locked,I want to unlock it ,please help me
Well of course the internet is not working if the laptop is locked. In fact, if the laptop is locked nothing is working, right?
So, why is the laptop locked? When you turn it on, what is it doing and what is it asking you to do?
And what is this Internet Security you mention??
The only Internet Security I know of is a Virus or Infection that calls itself Internet Security.
Don't get me wrong, Internet Security is vital, but it is process and not a product per say. There are things that end with Internet Security such as Norton Internet Security, McAfee Internet Security, Kapersky Internet Security, etc. The only product that calls itself "Internet Security" is a virus known as the Internet Security virus.
Is that what is popping up on your screen and blocking you from doing anything?
May 16, 2012 | HP Compaq nc6120 Notebook
Hello, I recently had a Toshiba Sattelite L455 that suddenly promped for a BIOS password on startup. There was never a bios password set for this laptop. So I found a workaround using the onboard...
You hit the correct jumpers for this model to remove the motherboard bios lock, which shows you have done your homework well. Toshiba, like Dell set a bios lock and HDD lock on some laptops for security reasons, often when the cmos battery needs changing, it manifests itself.
As to why you got this request for a bios pass is very odd, if you did not change the cmos battery, however, removing the battery as you state would not fix the hard drive problem. The hard drive will remain locked and if, as I suspect, it is a security measure, you will not be able to remove it and externally access files or even format it by slaving it in another computer or docking station.
Your best solution would be to contact a Toshiba service centre and explain the problem and ask them for a bios unlock code. IF this was installed at the factory, they should be able to remove it (you WILL be asked to provide proof of ownership)
I have heard of some laptops being "time locked", which is where the time/ date settings in the bios trigger a request for a bios password for security purposes, but never actually seen this occur. This might explain why the bios pass request appeared randomly as it did. There is the possibility that this was caused by a virus, although, again, I've never heard of this happening.
Jul 24, 2011 | Toshiba Satellite L455S5980 Notebook
I don't know how to lock it
Hi there! here's how you can do that. Hope it helps. :)
Security Settings
All of your phone's security settings are available through the Security or Restrict and Lock menu.
Accessing the Security Menu
1. Press > Settings > More... > Security.
2. Enter your lock code to display the Security menu.
Accessing the Restrict and Lock Menu
© Press > Settings > More... > Restrict and Lock.
Apr 20, 2011 | Sanyo SCP-2700 Cell Phone
I use an acer laptop and using wireless connection,however when i have connected to a network i try to open mozilla firefox and it says that no connection.in addition when i open the control panel and...
can us surf in explorer, if yes... then ur Mozilla FF connection setting need to change. under the setting option change the connection to explorer settings.
the lock symbol u c is not related to ur connection, it says that your system is secure from hacking and virus, and you r visiting a secure server...like https://
Dec 07, 2009 | Acer ASPIRE 4520-5141 AMD TK-57 1.9G 1GB...
Why my apple laptop is unlocked
Are you talking about a physical lock or some sort of software lock?
If you have shut down (powered off) your laptop, when you start it up you will get initial conditions for everything. If you have your preferences set to "automatic login" for the main user, that's what's going to happen. That's not very secure. If you don't want that, turn that preference off.
If that's not your question, state your question with more clarity.
Apr 12, 2009 | Apple iBook G4 Mac Notebook
Belkin Wireless G Plus MIMO (F5D9230-4)
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
