No sound in Divx movie played with divx player. audio properties are Tag 8192 Dolby AC3 Audio.
  • 558 Answers
You need a divx codec you can download free on there website Google divx codec
Posted on May 01, 2008
Why can't I play audio on certain avi and mkv files on Mountain Lion?
Sounds like it might be a codec that is not included in the OS or the applications you have tried. Can you try VLC player? It's one of the most versatile media players around and plays almost everything that I've come across.
Nov 28, 2017 | Apple OS X 10.8 Mountain Lion
Tip
How to convert XVID VBR MP3 and DIVX CBR MP3 using ConvertXtoDVD
Most Philips DVD players with DivX will play Stage 6 or VOD MP4 Video files if the FOURCC is set to DX50 or DIVX and the MP3 or AC3 audio is at a constant bitrate CBR of at least 192kbps, this is also the DVD Video audio standard in AC3, DTS or LPCM.
However with either DivX OR XviD video with VBR MP3 audio you will experience audio lag on playback the trick is to get the audio track in to a constant bitrate CBR and if possible with the audio frames Aligned on the interleaves as opposed to Split across interleaves.
If you plan on keeping the video in MP4 AVI v2.0 format then you MUST convert the audio to a CBR in either MP3 or AC3 format using one of the methods shown HERE.
If you plan on converting the MP4 video into DVD format you can first try to use the excellent ConvertXtoDVD this will attempt to convert the audio track into 192kbps CBR dolby digital AC3 audio whatever the source AVI audio.
If this fails to give you DVD Video without audio sync problems then you must convert the MP4 to a CBR audio and a FOURCC of DX50 to ensure Home Theatre compatibility.
on Feb 11, 2010 | Philips DivX DVD Player
Tip
Set VirtualDubMod to Align Audio Frames across Interleaves for better sync
The default for the this program is Enable audio/video Interleaving with a 500ms pre-load in VirtualDubMod,this is the recommended value, it is not an offset this is done in the Audio Skew Correction the same is true for its older cousin VirtualDub.
This will set the Audio Frames to "Split across interleaves" which can cause the audio to go out of sync with the video even if the MP3 is set to CBR a problem most known with VBR audio on standalone DVD players that that DivX capabilities. This is one reason why the preferences are set to warn you about VBR audio this is a screendump from VirtualDub
It is said that if the AVI has Audio frames that are "Aligned on interleaves" it will always remain in sync even with a VBR MP3 audio track.
If you experience VBR MP3 problems you can turn off the MP3 ACM and use VirtualDubMod MP3 encoder under here the default preload for AVI audio is set to 500ms as shown this is the same in VirtualDub.
If you are going to re-encode the MP3 audio to AC3 the audio gets split across interleaves with the default values MP3 seems to Align with Interleaves itself .
However if you Enable Frame Mode the resulting AC3 will get "Aligned Across Interleaves" (you can't do this tweak in VirtualDub by Avery Lee)
Options -> Preferences -> VDubMod -> AVI -> Enable Frame mode.
If you are OK with this then you can re-encode the VBR audio MP3 to CBR dolby digital AC3 audio "Aligned Across Interleaves" and know that your audio frames will be aligned with the Interleaves and AV sync problems on your DivX enabled DVD players.are over.
on Feb 10, 2010 | Philips DivX DVD Player
What formats does it play for movies?
The Iomega 1TB ScreenPlay MX HD can play these formats in upto 1080i:
Audio:
MP3
AC3 (Dolby Digital Encoding)
WAV
WMA
Video:
MPEG-1
MPEG-2 (AVI/VOB)
MPEG-4 (AVI/DivX 3.11, 4.x, 5.x, 6.x/XViD)
Regards,
Chris
Jul 05, 2011 | Iomega 1TB ScreenPlay MX HD Media Player...
Dolby AC3 Audio (code "8192")
Without the full error code, I have to assume this error ends with "You may need to install a Directshow decoder for this audio format."
Look on this page in the left upper corner, you will see :
Moviecodec Forums/Downloads , when you put the cursor on this, another choise can be maken, then choose below in that choise : Audio Codecs, when this has been opened you have to take the first of the row ( AC3 Codec ( tag 2000/8192
Clic on this one, save it to a place ( new folder )in your "received files " and then open it( double clic )
Put it in your " program files " following the instructions.When this is done, your movie will have sound.
It works with my movie
Mar 04, 2011 | Apple Computers & Internet
It say's, "this file contains
look up dolby AC3 audio player on google there will probably be a free download
Feb 28, 2011 | Computers & Internet
Im trying to use divx but come up with this error.......This file contains a track in the Dolby AC3 Audio (code ''8192'') format. You may need to install a DirectShow decoder for this audio format in order...
Try a web search on your error messages - you will be able to fix a lot of things just by doing that. You can get this video codec at http://www.free-codecs.com/download/GPL_MPEG-1_2_DirectShow_Decoder_Filter.htm .
It doesn't hurt anything to install all of the common video codecs. Most of them can read each other.
Oct 23, 2009 | Dell Computers & Internet
Audio drivers
more than likely your going to need a set of drivers Dolby AC3 drivers for WMP at http://ac3filter.net/projects/ac3filter this should take care of the audio another you should get is the DivX set vor video http://www.divx.com/en/win. these should do ya.
Jun 21, 2009 | HP Compaq nc6000 Notebook
Audio codec upgrade for DiVX Playing
You need to get the latest AC3 (Dolby codec).
Jan 14, 2009 | Audio Players & Recorders
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
