Question about Compaq Presario X1000 Notebook
I got this from another post and it is exactly what is wrong with mine.
How do I get an "inverter" and is this something I can repair myself?
Thanks,
dennis@cartcorp.com
"So once you think windows has loaded, under a bright light see if you can actually see your desktop, albeit very dark. Inverters can be sourced in US at around $20-50 so not too bad."
  • Anonymous May 30, 2008
    When I boot up the Windows music plays, all the appropriate lights come on but the screen remains black. This problem started yesterday, May 29, 2008 and has not occured before.
    Thanks,
    Coach
  • 79 Answers
Hi
adjust the brightness of the screen may u hav accidently turned to zero brightness.
if this doesnt solve then let me know.
Posted on Jun 18, 2008
Compaq Presario x1000 with no battery won't start off AC
Battery is needed to complete circuit. Too bad you didn't have the old one.
http://www.ebay.com/itm/Battery-For-HP-Pavilion-ZT3300-ZT3200-ZT3100-ZT3000-Compaq-Presario-X1000-X1200-/150853086051?pt=Laptop_Batteries&hash=item231f8b6b63
Not advertising, it is just an example.
Still doesn't work after Battery installed, post back in a Comment.
Suggest do not be so quick to toss it away.
Regards,
joecoolvette
Dec 19, 2012 | Compaq Presario X1000 Notebook
Will an Intel® Pentium® M
I don't know your exact CPU specs but I've taken a single core Intel M processor 2.0 GHZ from a Dell 800 laptop and put it into my wife's X1000 and have had no problems running XP SP3. My own x1000 computer reports Intel Pentium M 1600MHZ as CPU type.
Dec 22, 2010 | Compaq Presario X1000 Notebook
I have a compaq presario x1000 that wont let me get past the logo. It was working fine one day, but then I shut it down. The next morning I booted it up it the computer never went past the Compaq logo.
It is likely that the hard drive is bad or a memory issue. I would start by removing the hard drive and see if it goes past the compaq screen. If it does then you know what is wrong. If not message me and will walk you through the next step
Jun 30, 2009 | Compaq Presario X1000 Notebook
'03 compaq presario x1000
On a desktop pc u hear continuos beeping it's something to do with da ram so try replacing the ram or reseat the ram for help go to compaq.com
Nov 11, 2008 | Compaq Presario X1000 Notebook
On off button
Same thing happened to mine. I took it to a tech to fix it.
Oct 01, 2008 | Compaq Presario X1000 Notebook
Broken power button
They Have one for sale On ebay if you need..
Look here for your compaq presario X1000 power button bezel
http://cgi.ebay.com/APCL312M000-compaq-presario-X1000-power-button-bezel_W0QQitemZ230260679776QQihZ013QQcategoryZ60265QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope it helps.....
http://www.wnycomputerpro.com
Jun 11, 2008 | Compaq Presario X1000 Notebook
Compaq pressario X1000
yes. when the switch is turned on it activates the built in wireless card in your laptop. you can then connect to a wireless router
Jun 10, 2008 | Compaq Presario X1000 Notebook
Notebook screen stays dark
Make sure you check under a bright light that you can actually see the image.
This model is notorious for a bad video card (Radeon) that makes it seems like something is wrong with your screen but if you press down just above the keyboard it will work while you are holding it.
If you see an image you have one of two things:
Bad inverter
-or-
Bad backlight bulb
If you saw the screen turning pink or red on cold starts before your backlight is burned out and it's just faster and easier to replace the LCD.
If you just saw a flicker and then screen went black the inverter is the problem.
The inverter is a little circuit board that sends power to the backlight bulb, so even though the bulb is good it won't get power to light up. If the bulb is bad replacing the inverter won't change anything.
The inverter is located just below the LCD. Disconnect AC and remove battery.
Remove the rubber plugs along the top and the two oval stickers on the bottom corners. They cover the screws. Remove the screws and carefully pop off the bezel with your fingernails moving around the edge as you go.
Under that you'll see the inverter. Use a fingernail or flatblade to carefully pry the connector off and then unplug the wire harness on the other end. Install the new part. Test it.
If it's working, then reassemble. If it's still dark the backlight is shot or your inverter was a dud.
If it's the backlight, you can remove the screen now that it's open. There are just a few more screws on each side of the LCD and removing a couple on the lower brackets can help you temporarily raise the screen up from the lid to more easily access the screws on each side.
The connector on the back is very delicate. Walk it out with your fingernails and try to reuse the tape if you can. Never pull by the wires.
Replace and test again.
Again, make sure you can POSITIVELY see an image on the screen before doing this repair.
As i mentioned earlier the X1000 has a bad video card the makes the computer boot up and show a black screen and even boot into windows but will NOT display video on the LCD or even the EXTERNAL video out. You can test this by plugging it into a desktop monitor.
That will be $300 please!
Jun 02, 2008 | Compaq Presario X1000 Notebook
LCD Screen ib very, very dark... does not light.
You have one of two problems. Either your inverter has gone bad or your backlight is burned out. You can find both items as well as instructions on how to replace each from http://store.ccfldirect.com/lcdtutorial.html
May 01, 2008 | Compaq Presario X1000 Notebook
My Compaq Presario X1000 doesn't recongize my camcorder via firewire port.
It may be the problem with driver. Your OS may not contain the proper driver.Like in windows service pack 1 do not recognise some camcorders. either upgarde to service pack 2 or download proper driver from manufacturers site
Apr 21, 2008 | Compaq Presario X1000 Notebook
Compaq Presario X1000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
