Question about HP Pavilion a1200y (EK457AV) PC Desktop
Drive F can't get it to copy Word documents onto drive F
    President:
  • 1,944 Answers
You said that drive f is a CD/DVD burner. You can't save directly to a CD/DVD drive. If you would like to burn it to a disc, you need to save the file first and the use a burning program like Nero to burn to disc.
Posted on May 01, 2008
I am trying to copy from Word, onto my SanDisk USB2.0, 8gb - how do I do this?
On your desktop you should see the San Disk device icon. You can either drag the Word doc over to the device icon or you can "save to" device instead of to "My Documents".
Aug 27, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I don't know how to download music onto my hard drive
when your music starts to download a BROWSE option should open you can select your hard drive or a folder in my documents or once its downloaded you could right click select copy and then paste the music into the folder or select the music hold the mouse and drag and drop it into the folder
how to make a folder right click in my documents select new folder you can name it then My Music
hope this helps
Dec 24, 2011 | Seagate Expansion 1.5 TB USB 2.0 Portable...
Complete user manual as said to be available in document with product SPHDU2 I need more detail than "drad and drop copies of your critical files onto the drive" I am computer iliterate
Open "My Documents".
Hold the CTRL key down, and click the mouse on the first file/folder that you want to copy.
While holding the CTRL key down, click the mouse on the next file/folder that you want to copy.
While holding the CTRL key down, keep clicking to "add" more files/folders to your "selected" objects.
Release the CTRL key.
Click with the SECOND (usually the RIGHT) mouse-button on one of the selected files/folders.
Point at "Send To".
Click on the icon for your your IOMEGA device.
The selected files/folders will be copied.
When the 'copy' completes, do _NOT_ delete your original files.
Instead, keep those original files in your 'My Documents' folder,
and keep the copy on the IOMEGA. That way, if your C: disk-drive fails,
or if the IOMEGA fails, then you still have _ONE_ copy of your files.
Dec 17, 2010 | Iomega eGo Portable Hard drive 500 GB ...
I just bought an Iomega 1TB Prestige portable hard drive and every time I copy a single document in Word, PDF, etc from one drive and try to paste it onto the Iomega drive I get an "Access...
Can you copy that single document from the drive to a different folder?
Can you copy that copy to the IOMEGA?
Can you copy that original to the IOMEGA?
Nov 17, 2010 | Iomega Prestige 1 TB USB 20 Hard Drive
I have a Seagate 2.5" SATA Mobile HDD. How do I back up all of my word document files
You will need to attach it to your computer somehow, is it an external drive? Is it USB / Firewire? Once you connect it you can format the drive (it may come pre-formatted) and it will then show up as a drive letter in My Computer (E: drive for example). Then you can just copy and paste your word documents onto the drive.
Which version of Windows are you using?
Jun 26, 2009 | Computers & Internet
How copy ALL My Documents to removable disk Microsft Works
okay, assuming you have your removable disk attached to your computer and a drive letter is assigned to it (let's say K: for example) - open up Windows explorer and click on My Documents on the left side - then hit Ctrl-A - you should now see everything in the My Documents folder is now highlighted on the right side - now right click over the highlighted items and choose (left-click) Copy from the popup menu - this will copy EVERYTHING in your My Documents folder -
after the copy completes (could take a while if you have a lot of items) then in Windows Explorer click on the drive letter of the removable drive (K: in my example) - then right click over the area on the right and choose Paste - this will now put all the copied items to the removable drive
A few things to consider
- you didn't specify what kind of documents you're looking to copy so the instructions above will copy EVERYTHING under my documents - this includes My Pictures, My Videos, etc. and any and all folders or files under My Documents
- also this procedure COPIES the files to the removable drive - leaving the original files intact on your hard drive - if you want to MOVE them to the removable drive then choose Cut instead of Copy in the step above
Jun 20, 2009 | Computers & Internet
Cannot copy files from memory stick to computer.
may need a driver to be installed for the memory stick on the problem p.c . There may be a policy in place to prevent the driver being installed on the problem p.c..
Other cause may be stick is USB2 and computer at work maybe USB1 it may have another port for USB2 on the computer ?
Mar 06, 2017 | Electronics - Others
Not able copy folders from able to copy folders across from Passport drive onto PC desktop
hmm..is the drive visible in the my computer panel? and you could do a global search and copy and paste if that goes quicker..
Oct 15, 2008 | Western Digital Passport WDXML800UE...
I have plugged in my iomega portable hard drive and want to backup my computer. How do I do that?
If the drive connecting through a USB port you will see a new drive letter under my computer. You should use the backup utility of your computer to backup your PC onto the new drive or selectively copy documents from your computer's hard drive onto the portable hard drive.
Aug 25, 2008 | Computers & Internet
Can't copy onto CD-R
hmmm.copy or send to? sometimes those CD-R's work best as a backup, or a copy and paste option..
vista and 2007 should be fine, but I'd check on the office site to ensure you're up to date.
www.microsoft.com
check your computers warranty here 4 FREE
Mar 17, 2008 | Staples (10365CC) Media
HP Pavilion a1200y (EK457AV) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
