Question about Cameras
Hi i have a tamron 24-135 sp lens for cannon eos fit and it has developed a fault.when i switch the camera on it gives a 99 error,yet if i extend the lens to the 135 mm position everything is ok,i can then go to 24mm setting still ok,if i turn the camera off and on again back comes the fault.any thoughts? also i dont seem to find any tamron uk support contacts. regards phil langham
  • 51 Answers
SOURCE: Why do I get Error 99 in my Canon EOS 350 D?
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Posted on Jan 30, 2009
  • 149 Answers
SOURCE: tamron 35-105 f2.8 sp lens, aperture often
lens flexible pcb broken change it
Posted on Sep 09, 2009
  • 117 Answers
SOURCE: My Canon 400D Camera keeps coming up with error 99
Hi turn on the camera with the lens on set to tv and a iris of f22 and use the stopdown button if the lens stops down the lens is ok if not the lens is faulty may need a intuper replaced
Posted on Jan 11, 2010
Testimonial: "Many thanks for your help with this problem. What is a Intuper? I have never heard of this before."
Obertelli
  • 3006 Answers
SOURCE: Does the Tamron 18-270 f3.5-6.3 Di VC LD Lens fit
If it has the correct Canon mount then it will fit, but is still unsuitable.
The lens is designed for APS-C sized sensors, so the image it produces will not be big enough for the full-frame sensor on the EOS 5D. If you use it then there will be unacceptable vignetting in the corners of the images.
The angle of view of the lens will also be different to what you may expect: although it is an 18-270mm focal length it will have the same angle of view as a 28-420mm on a 35mm full frame equivalent camera.
I hope that my posting has helped you and only ask in return that you take a moment to rate my answer.
Posted on Jan 13, 2010
Testimonial: "Very usefull information. "
lock123
  • 6831 Answers
SOURCE: tamron lens error code 01canon eos 450d
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 19, 2010
Tamron 90mm macro lens communications error
Hi this is problem of innner flex damaged so just replace this flex and its done
If you want any more help
Khatricamera@gmail.com
Pic is attach only for your knowladge its not for your lens
Its like this
Apr 13, 2013 | Tamron SP AF 90mm f/2.8 Di Macro 1:1 Lens
HI I have a cannon eos digital SLR. When I try to take a picture error 99 appears on the screen. I do not know how to correct it. Will I have to send it back to the cannon company? Is there someway I can...
Error 99 and believe me I've been there is Canon's catch all error code cause if the camera can't figure out what's wrong it goes to Error 99. Canon doesn't release any information directly towards error 99 due to several different causes. That was the bad news. The good news or at least the better news is that most of the time error 99 is caused by dirty contacts between the camera and lens. At least this is the problem I'll address in this solution.
You will need a new pencil with a red rubber eraser, make sure the camera is turned off, remove the lens from your camera and put a body cap on. If you do not have a body cap lay the camera lens mount face down on a clean lint free surface. Take the lens and hold as vertical as possible with the rear lens element facing down and turn the lens body so you can see the gold contacts. Use the red rubber eraser to gently clean the contacts. Make sure they are clean and all rubber dust is removed from the lens and contacts. on the lens you may use a little puffer/blower or a lens cloth not a tissue. Do not use a liquid cleaner. Once you have finished the cleaning of these contacts either put a rear lens cap on or set the lens where it is not going to get knocked over sitting on a clean dust free surface with the contacts down. Now take the camera and as much as possible keep the lens cavity pointing down to eliminate any rubber dust from entering the camera, clean the contacts again gently with the rubber eraser clear the dust with a lens cloth not a tissue DO NOT use a puffer/blower at this point because it will only blow the dirt into the camera. Once you are satisfied that area is clean reinstall the lens make sure it's locked and turn on the camera. You should be "Good to go". Well lets hope so anyway. Error 99 can also be a problem with third party lenses like Tamron, Sigma, Tokina not having the up to date electronics to match your camera properly Error 99 can also be caused by requiring a camera firmware update but for now lets just go with cleaning the lens to camera contacts.
Jan 09, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
My tamaron 28/200 lens when fitted to. cannon eos 350 d. shows err 99 when switched on ,previosly ok ,disconect lens and camera functions ok,only have one lense
Try cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Sep 27, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Does the Tamron 18-270 f3.5-6.3 Di VC LD Lens fit the Canon EOS 5D Regards IH
Jan 13, 2010 | Cannon EOS 50D Digital Camera
My Canon 400D camera keeps coming up with error 99 I have cleaned the contacts on both my camera and my Tamron 28-200 lens.At first i thought it was my camera but I tried it with another lens and it...
Jan 11, 2010 | Tamron 28-200mm F3.8-5.6 for EOS
ERROR 99
try cleaning the lens contacts of your lens and camera.
Jul 31, 2008 | Tamron 18-200mm f/3.5-6.3 for Nikon
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
AF 70-300 causes error 99 in my Canon 300D
This is usually a torn flexible circuit or binding aperture in the lens. It'll have to go to a repair shop for replacement. About a $80 job.
Nov 04, 2006 | Tamron Zoom Telephoto AF 70-300mm...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
