Freezer working O.K. fridge coolish but not up to speed. Have cleaned condenser at back - still no improvement.Temporature guage has been on/off at intervals - have reset it but still performance impaired?
If freezer sections work and fan running fine, most likely iced up vents
for side by side the freezer vents is on right
and refrig vent in on left, check for icing
if iced up this restricts cold air flow
and sounds like your issues, you can use a hair dryer at distance
best idea is to unplug it for two days with door open
to ensure correct defrost, this also resets some components
Ours is running 60 degrees in the top and about 10 degrees in the bottom freezer unit. We took most of the contents out of the top refrigerator portion to no avail. I have vacumed the condensor coils as well.
I have the same problem with a Jenn-Air JSD2789AEB side by side. I have defrosted the freezer side and it is working fine and making ice but the temperature on the frig side is around 49-50 degrees 12 hours later.
