Question about Intel Motherboard
My usb hi! my usb in cpu doesn't work anymore! how can i use it again?
Hhahaha.. shame!
Posted on Jun 06, 2008
  • 53 Answers
Wow your cpu has a usb most processors do not have usb ports
Posted on May 01, 2008
I got a compaq evo n110 the cpu fan doesn't turn anymore
Try changing the fun first if the problem still persist then it could be a problem with the broad see a specialist for that.
Feb 27, 2012 | Compaq Evo N110 Notebook
My toshiba external harddrive usb 3.0 won't work
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps you
Sep 18, 2011 | Toshiba Notebooks Canvio E05a075cau3xw 750...
Have downloaded a driver for mustek 600cu but still not recognising scanner
First install software driver if finish, connect your scanner USB cable to USB ports of CPU(make sure that your USB ports working good, test also using your USB flash drive).then you can see on screen automatic detect your scanner. if not detected try to change your USB scanner data cable. then try again connect to USB ports of CPU.
Just let me know if not yet working.
Thanks for using Fixya.
Jul 13, 2011 | Mustek Plug-n-Scan 600 Flatbed Scanner
I have a samsung external dvd writer, now i've got a problem because it can not be recognized anymore when i insert it into my pc. what is the main cause of this problem and how to fix it? can you give...
Try to plug it to other USB port of your PC I recommend you plug it at the USB port at the back of your CPU..If this doesn't solve the problem try to clean your DVD drive lenses with a DVD cleaning disc..Still if this doesn't solve the problem perhaps you'll need to contact a technician or for worse buy a new external DVD..Hope it will help you..
Jul 11, 2011 | Samsung 20x External Double-Layer DVD...
Instal in XP
Hello, This external hard drive does not need a driver, even in XP. If you're using a desktop, don't connect it to the usb ports in front of your CPU case, instead, connect the usb at the back USB ports, if this doesn't work, try using a shorter USB cable and connect it again at the back.
Jun 19, 2011 | Western Digital Elements powered by WD 320...
Hi my blue light for the external hardrive turns on all the time but my computer just wont detect it \r\ndoes this mean that my hardrive doesn' work anymore? is there anyway i can all my files bac? thank...
If it used to read it, but doesnt anymore, could be a sign of a hardware failure. If another computer reads it, then it is probably a driver issue. Try to turn the power on, then insert the USB cable into the computer.
May 03, 2011 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Hi, I have an external disk connected to an usb port. Sometimes my computer stop to recognize the connection and my external disk doesn´t works anymore, until the next reboot. What can I do to resolve...
The only other solution other than rebooting is to remove the cable from the usb port and reinsert it. Sometimes the computer will recognize the drive and it will work properly.
Aug 13, 2009 | Microsoft Windows XP Professional SP3 Full...
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
I have a 1g Lexar usb key it doesn't work. My computer doesn't reconise it plus the light on the key doesn't flash anymore... pls help as i have my good photo's on it
It could be your USB port that's not working. Try inserting your flash drive into a different USB port. It is possible that the line connecting the USB port was accidentally removed or loosened inside your CPU. You can also try opening your CPU and fix the connections of the front panel wires to the motheboard.
Sep 23, 2008 | Computers & Internet
Webcam isn't detected
reconnect webcam usb port, then restart your PC. then, attact usb port again, try to attach first at front usb port of your CPU, if stil doesnt work, attach your webcam at the back usb port of your CPU.
Hope it will work.
Thank you.
Jul 30, 2008 | Microsoft LifeCam VX-1000 Webcam
Intel Motherboard Logo
110 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
