will try it, but the door is not jammed it will open as normal after the alloted time,everything seems as it should be the power light is on at the front, the door locks when closed, ready for a wash , but when i turn the programme button the machine does not try and fill up and start washing.i have checked the pipes to it and they are kink free and supplying water as they should but the machine programmes are not working at all.will try it, but the door is not jammed it will open as normal after the alloted time,everything seems as it should be the power light is on at the front, the door locks when closed, ready for a wash , but when i turn the programme button the machine does not try and fill up and start washing.i have checked the pipes to it and they are kink free and supplying water as they should but the machine programmes are not working at all.
You can't post conmments that contain an email address.
better to replace if kinked just disconect form both ends wherever its conected put new pipe on refill power assist resivwar and turn steering lock to lock when started
This works on the older troopers min is a 95 giv it try
A-Open the driver’s door. B-Insert key into ignition. C-Turn the ignition switch to the ACC position and then to the LOCK position three times. (This step must be completed within 3 seconds – go as fast as you can, or the system will not enter the programming mode.) D- Within 10 seconds, close and open the door two times. E-Turn the ignition switch to the ACC position and then to the LOCK position three times (again, do this within 3 seconds.) F-Within 10 seconds, close and open the door. Verify that the power door locks cycle once to confirm that the system is in programming mode. G-Within 20 seconds, press the LOCK button on the transmitter you are programming. Verify that the door locks cycle once. H-Within 20 seconds, press the UNLOCK button on the transmitter. Verify that the door locks cycle once to confirm that the system has accepted the transmitter’s code. I-Repeat steps 7 and 8 for each transmitter to be added. Remove key from ignition.
is the door lock light coming on if so then could be a clogged pump or bad pump. if lock light doesnt come on then may be a bad door latch/lock. may take a minute or two for light to com on once you turn it on .
check fuel pipe from tank.there might be some or sever kink.Also worth a chat at fords as they have a lot of exp with mondeo.check the air filter,it might be blocked.this problem also occurs when the ECU gets locked up.check the glow plugs if they are ok then you need to calidrate your injectors.
The door lock flashing all time has nothing to do with the weather, or pipes freezing up, it is a fault with the washer.
It is unlikely to be a faulty door lock, but could be a broken door catch spring or door catch problem, make sure you can feel the door latch in securely.
the other probable cause a fault on the main pcb where you programme the washer.
Another prob that can occur is a fault on the mptor caused by the brushes shorting on the motor armature, this in turn can blow a track of the pcb, and giving you the flashing light prob.
I would start by checking the motor first, if you are satisfied that the door is closing o/k.
Plz rate my solution.
Thanks.
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
