I can see the bolts holding the spider in place and can remover the belt wheel but can't tell if the rear of the outer drum is removable - can anyone tell me if I have to go in through the front or if I can prize the back of the outer drum off and access the front bearing this way??
Hi
In a washing machine, the bearings protect the drive shaft from over rotation due to the forces applied to the washtub.
Unplug the washing machine from the power outlet. Turn off and disconnect the washer from the water pipes. Pull the machine forward so that you have easy access to the entire machine.
Unscrew the lid's top two screws and remove the machine's top panel.
Slide out the machine's back panel.
Slide off the fan belt and set it aside.
Unscrew the drive shaft's end bolt. This is the bolt that holds the pulley into position.
Remove the pulley by placing the screwdriver underneath it and gently leveraging it off.
Remove the drum's three bolts that hold its spider bracket into place. If the bolts are sticking use, rust remover and degreaser to loosen them. Do not apply too much pressure to the brackets or you will strip them.
Tap the spider joint gently with a hammer while pulling on it. The entire joint and the bearings should slide off.
Clean up the spider shaft, removing all rust and debris using cloth diapers and rust remover and degreaser solutions.
Tap the new bearings into place.
Tap the new drive shaft seal into place. The drive shaft seal should always be replaced with the bearings to ensure water-tight protection for the machinery.
Reassemble to washer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
i have taken the whole drum out of the shell as i call it. How do i change the bearings? I am excellent at diy and there isnt much i cannot eventually figure out but this is baffling me. I have the drum on my floor with the spider on it, i have taken the screws off that are attached to the spider but it doesnt budge. aslo in the centre of the spider is a 3 spoked wheel with a t40 star whole, does this need to be removed first? it is very stiff and has already snapped 2... yes 2 star sockets.... please advise
ok does anyone know if it is left handed or right handed thread and the t40 bolt?
Hi, yeah my bearings collapsed on this machine as well. Been sounding like a jet engine for a while now.
I snapped my one and only T40 can't work out if it's a left or right hand thread. Would appreciate it if anyone who manages to get the spider off the drum can tell me which thread it is. Going to try some heat next :)
carn,t get the central bolt out im the same as everyone else snapped two allready..
