Question about HP Pavilion dv1000 Notebook
Pc how how do i turn on pc?
  • 53 Answers
Hit the power button
Posted on May 01, 2008
PC Not Turning On
It may mean that your video card driver is corrupted. Pull the card, start the computer, and remove the video drivers. (If you know how, remove them from the backup directories, too, just to be safe.) Then try to reinstall the video card just like it was new.
Mar 18, 2014 | Gateway SX2800-01 PC Desktop
Tip
A PC trick ;D
You might have heard and searched about shutting down remote PC.But, have you ever wished to turn on your PC remotely and access your file from FTP server and shut it down when not needed? Well you can. Sounds crazy isn’t it?
With simple tweak, you can turn your PC on from LAN. This will be a lot help if you have FTP server enabled from your desktop and you may want to access it from internet occasionally. Turning your PC always on will not be good as it will consume lots of energy. Even more your PC will be much more venerable for uninvited access.
To prevent this remotely turning on your PC can be good alternative.
To turn your PC on, all you need is the MAC (Physical address) address of the PC that you are turning on and Wake up on LAN or Power management from PCI enabled in the BIOS in the PC you want to turn on Remotely.
To check if it is enabled or not, go to BIOS setting in your PC by restarting and pressing Delete key(may varry according to motherboard). Go to Power Management Options, search for Wake up on LAN or Power management from PCI or any similar terms and enable it.
If you don’t see any option to manage power for PCI adapters then it might be possible to do it in Windows mode.
To do this, boot your computer to windows, go to Device Manager. Under network adapter choose the Network card that will be used to connect to LAN, i.e. your ethernet card.
Right click on it and choose properties. Go to Advanced tab.
Now in Property box scroll down to Shutdown Wake up or any similar terms. Select it and Enable it.
You may require a reboot after this.
Now your PC is ready to be turned on from LAN. This will enable to manage power from PCI devices like Ethernet cards. What it actually does is, configures BIOS to turn the PCI Ethernet card to grab some power even if PC is Powered Off. If any computer from LAN sends some command to PCI card then will will power on your PC.
Now anyting left to do is to have a tool to turn your remote PC own from remote location. I often use this tool since its free and customizable. With this free tool you only need to enter IP address of your PC and it will automatically get the MAC address of it. If required you have password field to enter.
Pressing Turn On button will turn on the PC with specified MAC address or IP address.You can also check if the PC is on or off.
I really hope this helps you :)
on Jul 06, 2010 | Computers & Internet
I have three ibm 8303 pc n that was off for over 2 years and when i tried to open it again last week it wont open.i cleaned inside but then it worked for a while after i replace ram.but the problem now is...
wipe your ram cooper connectors with pencil rubber
and get tissue swirl it until it looks like the stick then wipe the ram banks inside it should work fine after tat its a dusty problem
May 29, 2011 | IBM NetVista PC Desktop
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
Gateway LX6810-01 wont turn on now
1. how many beep sounds do you here and in what sequence ?
2. please look at the small blinking lit at the back of your pc most of the time thir combination of blinking speeks its problem.
2. check/remove if you install new hard ware on the board
Jun 30, 2010 | Gateway LX6810-01 PC Desktop
PC turns on and off like blinking
If you have another PC laying around that's got a power supply high enough to run the one you're having problems with, consider swapping them out.
Though it could be *********** board, it would be easier to swap PS's and see if the issue goes away. If not, it may be your MB.
Jun 28, 2010 | Foxconn 661FXME Motherboard
Turns off suddenly
Hi guest, if your computer turns off suddenly, try these steps:
Turn off your pc, remove the cables on the battery, remove the battery on the pc. Then push the power button for 5 seconds and then reinsert the battery and the cables. Then turn off the pc.
If symptoms persist , please call your technical support of the brand you brought for possible repair.
May 15, 2010 | Toshiba Satellite M55-S331 Notebook
My speakers dont work
Why would they work with PC turned off? Aren't they attached to your PC? If they are then they only work when PC is on.
So turn PC on.
Jul 11, 2009 | Computers & Internet
Turn off the pc automaticly
i use this to turn off my pc automatically. easy to use, lots of nice features.
http://www.ampsoft.net/utilities/WinOFF.php
Dec 19, 2008 | Acer Aspire T310 PC Desktop
TO noggin
remove all pwoer connector from motherboard and short green and black wire in supply shocket.If supply is run then it is the problem of motherboard.
Feb 28, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
HP Pavilion dv1000 Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
