Question about Pioneer Car Audio & Video
I have a pioneer deh-p8800mp headunit and premier prs-d1100m amp how should i connect them and setting the right gain and should i use rca's or the speakers rca's
edwardjwoods
  • 372 Answers
SOURCE: wiring diagram for pioneer premier
wiring for deh 3600????
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
Posted on Aug 18, 2008
Eagleeyes
  • 199 Answers
SOURCE: I have a Pioneer DEH-P55BT
hi we can fix this problem for £43.99 inc return postage to uk main land
please see www.blueice-electronics.co.uk
Posted on Nov 25, 2008
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
e-bay
Posted on Feb 02, 2009
Benimur
  • 6966 Answers
SOURCE: Connecting Pioneer DEH-2000MP to an amplifier
Hi and welcome to FixYa,
You would need a special adapter that connects to the speaker wires of the Pioneer DEH-2000MP and converts them to line level RCA ports. Something like the image below and available from here or most car stereo stores.
Good luck and thank you for using FixYa.
Posted on Feb 13, 2009
  • 40 Answers
SOURCE: need a user manual pioneer headunit
Here you go. Go to the link and scroll to the bottom enter the security code. Good to go.
Posted on Mar 26, 2009
Pioneer premier deh-p880 prs faceplate opens when you turn car off
The face folds down to give you the option to remove the face if you want. It will return to the upright position a few seconds later whether you remove the face or not. There should be a tab on the underside of the face you can push should you decide to detach the face from the chassis.
May 07, 2012 | Pioneer Premier DEH-P880PRS
I have the pionner deh p7300 i want to hook up a ipod i have a sub woofer and amp. on the back of the headunit i have rca plugs for the amp in the rca plug on back of unit. the there are 2 other sets of...
Buy a rca to aux 3mm plug then you can connect to aux port.
RCA out is for the signal to the amp from the Head Unit. Mic is probably for your cell phone.
Am pretty surprise that an HU like that doesn't have USB Ipod support?
Feb 06, 2011 | Pioneer DEH-P7300 CD Player
I have a metra turbowire 70-1857 wiring harness, and i am lost at connecting it to my pioneer aftermarket DEH-1100MP. I have the harness hooked up to the amp in the trunk. and strung through car and in the...
well head units usually dont have just rca inputs....but the outputs can be changed to rca style with adapters. the speaker level outputs are what you need to change....good luck
Apr 25, 2010 | Metra Turbowire 70-1857
How to set the time
Press the source (src) button, and hold until the headunit shuts off. Then Press the function button and hold for 2 seconds. The clock will come up with flashing numbers, use the up and down buttons to change time, and left and right buttons to choose between adjusting minutes or hours. This is the way my pioneer unit is i'm guessing yours is probably same, give it a try hope it works. If the function doesn't work use the audio button.
Oct 01, 2009 | Pioneer DEH-P470MP Premier In-Dash...
Jan 23, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Aux and sub settings
you have to turn the headunit off using the headunit (there is a button that says off or power just cant remember which one) once its off and is displaying only the time you hold the function button and all the other options will come up.
Jun 29, 2008 | Pioneer DEH-P6400 CD Player
Lights dim
3000 watts divided by 12 volts=267 amps...how hot is your alternator...have you considered a separate alternator or a battery isolator?
Jan 09, 2008 | Pioneer PRS-D5000SPL Car Audio Amplifier
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Connecting a amp
It has a remote output if it also has RCA pre-outputs. The remote output wire is blue with a white stripe.
Sep 24, 2006 | Pioneer DEH-1630R CD Player
Car Audio & Video Logo
205 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
