Question about ViewSonic VX2235wm LCD Monitor
Pink Line on my LCD
There is a single Pink Line coming from top to bottom on the left side of my screen. Can any one please help.
  • 3 Answers
Hello does you still have the monitor maybe i can trade you somethinf for it i could use the parts to fix another unit i have lmk thanks
Posted on Sep 10, 2008
Screen has vertical line on left side top to bottom,tv turns on when plugged in back lights come on but no menu or display of any kind,no 12 or 24 volts
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 14, 2016 | Vizio E422VL 42 in. LCD HDTV
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of line from primmer bulb goes to top port of carburetor. that is the way they go is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
There is a pink line on top of my screen of my lenevo laptop
Sorry to say that this is an indication that the LCD display is failing in that one line. It doesn't
mean that other parts of the display will fail. It may work this way for years to come. Unless it is really annoying or covers more than one single line, such as an inch or so, it isn't something that will cause damage to your laptop. I wouldn't go to the expense of replacing the LCD over one line.
May 11, 2011 | Lenovo 3000 Y410 Laptop
Vertical green line on left side of my laptop lcd
lenovo G450 a vertical line appears on the right side of screen. it is of pink colour.
Jul 03, 2010 | Samsung 204T 20.1" TFT-LCD Monitor
I have a Vizio SV420XVT. There is a green line from top to bottom on the right side of screen. Help me fix this, just went out of warranty
A single line out means a bad LCD panel..The cost for parts will exceed the cost of replacing the TV...
Jul 23, 2009 | Vizio SV420XV 42 in. LCD TV
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical line on TV
usualy this problem is cause by the lcd drive board.
Oct 09, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
ViewSonic VX2235wm LCD Monitor Logo
156 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
