Question about ASUS M2N-E SLi Motherboard
New motherboard drivers
Hi any help would be apprieciated,my brother down loaded the latest drivers for my motherboard as he said they were well out of date! downloaded them rebooted and nothing, a sickly beep a little bit of hd action(led) but no boot up,bro said i think ur motherboard is fried,so i now have another motherboard same as old but no boot at all no beeps no hd led any ideas please?
  • neilwilliams May 01, 2008
    hi damian, thanks for the response,the board was off ebay supposed to be new old stock but it did have a bent pin on the hd led (by the sata plugs)and had some dust on it..:(,i put my old board back in and its the same hd tries and a sickly beep so i think its the new board is just as dead as my old 1 they are both m2n-e sli green,are these boards weak?
    and thanks again ;)
    hi dami is it the chip covered with the ali cooler,i took the cooler off to find the thing is welded bonded then nailed on the board dont think that1 is coming off easy :)!if it is that1 of course!
    neil
    Problem Solver:
  • 23 Answers
Hi
Sounds like the BIOS corrupted while updating. It's usually easiest to just buy a new motherboard. As for the second one could i please get more information. Is it new? Are you 100% it's plugged in correctly? They usually don't just do nothing. You usually get a sequence of beeps alerting of an error. This may mean a power supply issue.
-Damian
Posted on May 01, 2008
  • Damian LAng May 01, 2008
    Sorry i have never heard of them -damian
    Just a thought. Since they are both the same model you can try putting the BIOS chip out of the dead motherboard into the half working one. Worth a shot. I can provide pictures of what it will look like if you need. In some cases you may need to solder but usually not.
    -damian
The printer is in german.i nid to change the language. secondly the output is to poor and do not seem to differentiate especially the black color.pls for both solutions printer mark:mfc 250c from brother
Which Operating System you're using if you're using windows XP SP1 SP2 and SP3 do as below
Right click on the desktop -> properties -> Hardware -> Device Manager find the printer drivers uninstall them and reboot the system and load the drivers it can fix your problem. If you're using the latest version of window 7 then go to the following link and download the latest driver and install it before installing the latest driver uninstall the older driver as said early.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=mfc250c_all
Thank you
Keerthyinfo
Aug 31, 2011 | Office Equipment & Supplies
I WANT TO DOWN LOAD THE MOTHER BOARD DRIVES FOR COMPAQ PRESARIO MODEL 7540
Visit the link http://www8.hp.com/in/en/support-drivers.html to download the latest drivers.
Regards,
Muhaim
Jun 17, 2011 | Computers & Internet
I have bought a new laptop but cant find the software to install my printer! what should i do? the model is mfc640 cw
Hi:
Just go to the brother support page and download the drivers, and you should be good to go. You can even get an electronic copy of your user manual.
Here is the link:
http://www.brother-usa.com/Support/
Apr 14, 2010 | Brother MFC-640CW All-In-One InkJet...
Brother MFC-7340 Status monitor offline
Is it giving any errors when you try to print?
Sep 22, 2017 | Brother MFC 7420 All-In-One Laser Printer
Prints blank page, then ERROR: undefined
When you press and hold down the Button will it give you a test print. Have you down loaded the latest drivers from brother.com.. Also does it do it with all programs.
Feb 03, 2010 | Brother HL 5150D Laser Printer
Brother HL-2140 printer driver problem - won't load
Uninstall the completly the printer driver form add and remove program and dissconect the printer cable and restart the computer. after that download the latest driver from herehttp://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/monolaserpri/hl2140_all.html?reg=us&c=us&lang=en&prod=hl2140_all and install it.
Nov 13, 2009 | Brother HL 2140 Laser Printer
Need an onboard ethernet driver
You can download the required drivers from:
http://www.asrock.com/mb/download.asp?Model=K8%20Combo-Z&s=754/939
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Sep 03, 2009 | Asrock K8 Combo-Z Motherboard
Sistem build on ecs p4m800pro-m motherboard shut down every time
I had the same problem, make sure the connector is plugged in the right way, use USB0 as the manual shows, check the front PCB make sure it's not shorting out at all.
I had the connector backwards.
Mar 24, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Problem in audio
Without knowing the model number or manufacturer of your motherboard I would say check the manufacturers site to make sure you have the latest audio drivers. ALSO a general rule of thumb is that when you buy a new motherboard the drivers on the bundled cd/dvd are generally never the latest. Always check the manufacturers site for the latest, it is a common occurrence that motherboards are shipped with broken drivers just to get them out the door, the correct drivers will be on the site.
Oct 15, 2008 | Intel D102GGC2 Motherboard
Unable to load audio driver for asus mother board pl5pl-cm
First, make sure the onboard audio is enabled in the BIOS. Then make sure it's listed in Device Manager, then download the latest driver from the Asus website.
Aug 03, 2008 | Computers & Internet
ASUS M2N-E SLi Motherboard Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
