Nokia N79 Cellular Phone Logo
Posted on Aug 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not able to use sms timer when i send sms it will directly send i dont get the option to schedule later.
IT Solution
Level 3:
  • Nokia Master 805 Answers
  • Posted on Aug 16, 2010
IT Solution
Nokia Master
Level 3:
Answers
805
Questions
Helped
156551
Points
2358
You can format your mobile by using these key.
*#7370# then it wants restore factory settings press yes. then it wants lock code. press your lock code. remind that your default lock code is 12345. thanks and enjoy that
Is it possible to get results of the case few days later via SMS without any paper showing the results?
anything is possible if you want to find out about your case or verify verdict notify lawyer directly
Can't send sms
The conversation style for SMS is unfortunately not available in the OS version used in W595. This feature is first available in the later versions of the OS which you will find in later phones.
There is no future plans for changing this in the OS version used in W595.
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
My Blackberry Bold 9700 seems to use messenger screen for sms's. After every line I hit the enter key: it sends an sms.
it could be because you have the "press enter key to send" option set to yes. go to options, then go to sms. then you will see the option press enter key to send, set it to no so you wont send sms when pressing the enter key.
hope this helps.
4helpful
2answers
Cant send sms from my Nokia E63
go to your message settings and check the message center number to see if it is correct.this can hinder your text messages from going.i hope this helps
I cannot send or receive sms messages or make
you have wrong network seleckted you can change settings in icon messages there settings and there you can find network options then choose your network.
Cant send sms from my Nokia e71 after a trip to the uk.
I am trying to send an sms but Nokia E71 gives error that close any application and try again later or unable to send an sms.
Please help
i dont have sms either on my blkberry 7520 nextel said my phone was not compatible but we have the option to mms which is a txt and a media message together so to send an sms just use the mms icon and as for your phone handheld not working try going to try going to ur phone icon on the home screen click the track wheel scroll down to options go to general options
ok from top to bottom should be never , never , yes, most recent, yes , yes, and volume should be 100% ok if that doesnt work try this all same untill you get to phone options click on push to talk then make sure speaker is on phone only says yes silence dc no silence direct no silenc group no good luck let me know if it works
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
