Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Strange Noise - Creaking
Constant noise (like a squeaking wood floor or washboard); stops only when freezer door is opened).
  • brandon4wyo Jun 05, 2008
    I have a kenmore 596.57043600 26" side by side with the same problem. Creaking sound when freezer door closed, stops immediately when door is opened, and starts again if you depress the door open sensor. The fan that blows from the back of the freezer through a duct directing air over the ice cubes seems to be quiet. The sound seems to be originating from the front of the ice maker. Sound comes from inside or just behind a part listed in the manual as part no. 12582501 Cover, Ice Maker. Seems more like a creaking of plastic on plastic gears?
  • sparverius Sep 23, 2008
    We have the same fridge and same issue.  I followed JRennie's advice, cleared out a coupla jammed cubes, and all is well.  Took 10 seconds.  Easiest "fix" ever.  Thanks.
I had the same problem. My fridge would make a creaking sound as soon as the freezer was closed. I took 10 minutes to trouble shoot the problem and pinpointed that it was coming from the icemaker. After wondering if I was going to have to replace it, I noticed a piece of ice wedged in a way so that the ice maker arms could not fall into the basin to make ice. The sound was the motor creaking because of the jam. Removed the ice and the sound went away. Now, I'm sure the motor will **** out in a few months since it has been jammed for 2 weeks burning up the motor. Oh well. Hope this helps.
Posted on Aug 09, 2008
  • 828 Answers
There may be a fan switch that shuts off the freezer fan when the door is opened . with the door open locate a push the button in. If the noise is heard at this point the problem is is the fan motor bearings. Replacing the fan motor may solve the problem in this case.
Posted on May 03, 2008
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Freezer has constant noise. When we open freezer drawer, noise stops. Could this be the fan?
usually the fan runs with door open as well. how ever u may have a problem with fan hitting something if it has come loose or off its support bracket, if u have an ice build up in freezer usually due to defrost problem the fan may make funny noises also
Mar 13, 2015 | Samsung RF4267HARS Stainless Steel French...
Samsung rs2630sh making noise and stops when the freezer door is opened
Sounds like you fan at the back. Mine is doing that at time for I've been having trouble with a drain valve plug and putting pressure on the whoe unit as well as the floor :(
Jan 20, 2013 | Samsung RS2630SH Side by Side Refrigerator
The freezer area makes constant noises groaning whne door is closed, stops when door is opened
I'm going to say it's a bad bearing in the fan. It shuts off when the door is opened so as to waste as little coldness as possible.
lp
Dec 29, 2010 | Amana ABB1927DE Bottom Freezer...
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
How can i roll the refrigerator out to vacumm the coils?
open the freezer and when the drawer stops you can pull from the door and it should roll . make sure that a foor is not set in front to prevent roll out .. mm . different ways to get any frig out depends on the floor its on . wood is easy carpet not so easy and tile has grouves and make's it hard. so just use you head . i use nylon slides to help an carpet and to protect wood floors . some dent easly ....
Oct 14, 2010 | Amana AFD2535DES French Door Refrigerator
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Constant buzzing noise
it sounds like your fan may be hitting on something
Jan 04, 2009 | Dacor Epicure EF42BNDB Side by Side...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
819 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
