Question about Sharp EL-330AB Calculator
SETTING TAX RATE
HOw do I set the TAx rate on a sharp Elsi mate EL 330a it is currently set at 9 and I obviously need to change that to 17.5
help driving me mad and no instruction manual on line tells you
  • 3 more comments
  • deeneyd May 01, 2008
    fast response and correct response. thanks
  • ykeyser Aug 14, 2008
    Hi please help me to re-set my tax rate on my sharp ELSI MARE EL-330A Calcularor
  • highlees Oct 14, 2008
    I have managed to change my Tax Rates but dont really know how I did it, I just kept pressing the buttons, The instructions dont really give me a step by step guide on what buttons to push to change them.
  • uspower
    uspower Jan 04, 2013
    enter your tax amount ie 14 press 2nd then press tax +(Rate set)
  • Anonymous Mar 21, 2014
    I have followed instructions to set the tax rate; how do I clear the tax rate?
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
Posted on Jan 29, 2009
    Sergeant:
    Champion:
  • 333 Answers
The instructions are for changing the tax rate are at the bottom of th sescond page.
http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/EL-330A-_E#
Don't forget to leave feedback 'fixya' if it works!
Posted on May 01, 2008
  • boff1 May 01, 2008
    Thanks a lot - You are on your own with the tax though!
How do i change the tax increase rate on my sharp EL-1197pIII
Move 'GT' '.' 'RATE SET' selector to 'RATE SET'
Tax / discount rate: • Press the TOTAL key twice, enter the tax rate, followed by the TAX+ key. •
Press the TOTAL key twice, enter the discount rate, followed by then TAX- key • A maximum of 4 digits can be stored (decimal point is not counted as a digit). Note: • Be sure to set above noted selector to the "•" position after storing an each rate. • For the conversion rate and the tax / discount rate, a single value can be stored for each. If you enter a new rate, the previous rate will be clear
May 27, 2016 | Sharp El1197P111 Printing Calculator
HOW DO SET TAX RATE ON SHARP ELSI MATE EL-2125
Easy. Press M- key [has RATE SET] above it. This will shown your current setting say 17.5. Amend to 20.0 and Press M- key again. Rate should now be set at 20%.
Test by entering:
100 and pressing +TAX key - Answer should be 20.
100 and pressing -TAX Key - Answer should be 83.33
Jan 04, 2011 | Sharp EL-330AB Calculator
How do you set the tax rate
Example: setting 5% tax rate
1. move mode switch to 'rate set '
2. press 5 (for tax rate ) followed by TAX+ button
3. Move mode switch to GT
to add tax to e.g 200 type:
200 TAX+, the result is 210
Feb 16, 2009 | Sharp EL-1197PII Calculator
Setting tax %
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Dec 18, 2008 | Sharp EL-1701C Calculator
Setting tax
If the model is EL-2125 , and not 2125C or 2125E the following will work
1)switch on
2)press CE and then CA (you should see 0. with small 00 in top left hand corner but nothing else)
3)press M- button (rate set button),current tax rate 17.50% will appear with tax at left hand side
4) type new rate eg 15.00 (making sure to hit the decimal and two zeros, tax at the left and % should still be on the screen)
5) press M- (rate set button) (small 00 will appear in top left hand corner)
6) press = ( new rate and G will appear small 02 in top left hand corner and = sign below it)
hope this works for you, please let me know either way
David
Jul 31, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
NEED TO SET TAX RATE
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5% you enter 9.5, STR, TAX+.
now it functions as (amount entered) plus tax. Example- find the total with tax for a purchase of $14.99 14.99, TAX+ Calculator will show 16.41
Jun 05, 2008 | Sharp EL-2192Rll Calculator
Set tax
To set your tax rate:
1. Be sure to switch to "rate set" from GT
2. Enter the tax amount like so - if your tax rate is 7% type in 7%
3. Go back to the GT setting and it should work...at least that is how I fixed mine! I did the same thing last week & have no manual!
Hope this helps you
Mar 03, 2008 | Sharp EL-2196BL Calculator
Set tax rate for Sharp EL-1701C
It is glorious!!!
Jan 20, 2008 | Sharp EL-1701C Calculator
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
Sharp EL-330AB Calculator Logo
7,801 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
