I own a maxtor 500gb external hard drive, which is powered by the mains, i want a usb cable which will power it from a laptop, is there such a thing. i found a usb power booster, but not sure if this is correct.
  • 106 Answers
ASK FOR THE ide TO usb CABLE IN MARKET. ITS AVAILABLE...MOST LIKELY IT WILL SOLVE YOUR PROBLEM.
Posted on May 01, 2008
How do I connect the hard drive for Maxtor One touch
Just use a standard USB cable to run from the drive to the computer's USB port, and connect the power adapter from the wall to the drive.
Feb 16, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor one touch 4 plus will not power on even after replacing power supply
Have you tried it in different outlets? Is it also connected to your computer via the USB cable while it is plugged in?
Aug 27, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Do I need only one cord (usb) to connect to my laptop?
The "physically-smaller" external hard-drives draw power through the USB cable.
The "physically-larger" external hard-drives require an external power-supply (just like a laptop requires an external power-supply).
Check the casing for a plug where the electrical power would come in; if none, then the unit will draw electrical power through the USB cable.
May 31, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My computer stopped recognizing my seagate
same thing happened with me, Looks like your pc usb slot is not providing enough power to the drive wither use a Y - USB cable (comes with three USB ends ; where in you will insert two USB cable ends to two usb ports on your pc and the other to ur hard disk) or buy a powered USB root hub.
Mash
Oct 18, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Something Dopped on maxtor 500G, Now not reading - making beep
two thing could be the power supply in the external box or it could be the drive it self
go to maxtor.com and download the software to test the drive
Aug 11, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor external hard drive stopped working
How is it connected ? USB?
If you start w/o Maxtor connection is your PC starting correctly?
Is issue showing when you connect USB cable on working PC?
Jan 04, 2009 | Acer Extensa 4620 Notebook
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to correctly disconnect maxtor 500 gigabyte external hd
Hi, Normally the steps would be: 1. In your PC, in the System Tray, click on the "Safely Remove Hardware" and then on the "Safely Remove USB Mass Storage Device-Drive(?); 2. Unplug USB cable; 3. Power down external device. Hope this be of some help/idea. Good luck and kind regards.
Sep 17, 2007 | Maxtor OneTouch II external hard drive...
Open Questions:
Computers & Internet Logo
David Payne
David Payne
