My CDRW800 is not work. MY PC Keep telling to incert a disc and a notice appears telling my to end the program.It will not play or record. I am uesing Windows XP.
    Genius:
  • 2,785 Answers
Just try by reinstalling your cd burning software,if the problem is not solved then try cd from other brand,if problem still persists than try to clean you cd lense by cd lense cleaner,if the problem remain than try by changing data cable,if problem is not solved than change the drive
Posted on May 01, 2008
Burning vhs to dvd disc on HP laptop w/roxio problem.
Try using different discs from other manufaturers . if this don't help try using a different burning program like PowerIso. and to make sure the problem isn't in your laptop try to burn some other files and see how it goes.
Jan 22, 2014 | HP Computers & Internet
Emerson DVD Recorder
sounds like what your doing is correct, See if you can locate a reset button on it and reset it. Did you try connecting to the TV that it worked on previously? Let me know.
Nov 10, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
Unit will play pre-recorded dvd's but when trying to record on any blank dvd disc it say's read then preparing and then invaid disc ?
Older DVD players (as well as some lower end products) will not play computer recorded disks. Another option may be which DVD are you recording on. DVD+R or DVD-R. Some players will only play one version. (usually -R I believe). Or could be a problem with youtr authoring program. Try a different program and/or type of DVD Recordable disk.
Aug 13, 2008 | Televison & Video
My gateway system will not play cd or dvd
See if you get any error Code If the drive could work enought to open the Tray and close it.
try to play the files on the disc manually.
if the disc you have incerted is detected in My computer(computer in Vista)
Jul 17, 2008 | Gateway Computers & Internet
Insignia dvd player wont play some discs
How to unlock a dvd player Insignia NS-H2002-U for region free
Insignia NS-H2002-U
With disk In the player (must be allowed region on you dvd)
Press stop in the remote dvd control 2 times to have a dvd screen in your tv
Press 16719 in your remote no matter what appears in the screen, at the end the region menu will appear
Using down arrow go to region that you want, “0” is for region free.
Press ok and enjoy it.
If do not work, power of your dvd, turn on again, incert allowed dvd movie in your insignia dvd player, when start reading disk, press stop and the press setup in your remote control, set uo dvd screen appears, then press 16719 in your remote, region menu will appear and use down arrow to select your region code, zero is for all regions.
Enjoy it
Feb 17, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Playback of recorded programs
try formatting the disc. it will erase everything on the disc and you can start fresh. try this with all the discs.if the problem keeps happening, try new discs.
wg
Feb 03, 2008 | Panasonic DMR-ES20EG DVD Recorder
Disc will not play or record message disc empty disk full
did you try a dvd movie do they play if so buy a different brand of blank dvd this happened to me i use
dvdr= sony ok
retail plus ok wal-mart brand
imation ok
at&t nogood on the rca machine
dvdrw= dataware ok
imation ok
cdr =tdk ok
these are all the brands a know are working on rca machines!
but keep in mind you can buy the most expensive blanks and they may or may not work on different machines
Dec 04, 2007 | RCA DRC8052N DVD Recorder
Won't format and or won't read disc
I have a similar problem in that it will not record at all or not record very well.  It has a drive inside like a PC DVD drive called the DVD RAM drive. The horrible clunking (grinding) sound is the disc slipping in the spindle. Unfortunately here in Australia the fix is to replace the whole drive (AU$350)!!
I have opened it up and tried to adjust the force of the spindle and it works for a while.
Hope somebody has a better solution.
Dec 03, 2007 | Panasonic DMR-ES10 DVD Recorder
Not working
Astonishingly, assignment of announcement to phone line is not documented in the user manual. Tech support was totally worthless concerning this issue. I had to discover it by trial and error. To assign an announcement to a specific phone line do the following:
1) Record your announcement message for a, b, c, ao, etc. as documented
2) Press program
3) Keep pressing the feature button until ANNC appear at the bottom of screen, line 1 appears at the top, and the letter 'a' appears in the middle.
4) Choose the announcement to be assigned to Line 1 by pressing the select button
5) Press the feature button again. Line 2 appears in the display.
6) Repeat step 4 to select the announcement to be assigned to Line 2.
7) Press program button, or take phone off-hook to end the sequence.
Shame on AT&T for such shoddy documentation, and lack of support for their products!
Nov 09, 2007 | Lucent 1872 Corded Phone
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
