Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
No picture when i turn the tele on there is very clear sound but no picture its just black, please help
  • Wylie7339054 Dec 21, 2008
    My Samsung (less than 2 years old) recently started to have intermittent problem - good sound, but screen would go black. Is there a permanent solution, as have no extended warranty
  • Anonymous Feb 04, 2009
    i have the same problem but mine is 46'' model # ls4692dx/x 2006 norma thanks
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Change ur backlight inverter
Posted on Nov 10, 2008
Tele has sound but no picture
Time to replace your lamp on your tv.
Mar 20, 2015 | Hitachi 62VS69A
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
Help- I have a TV/VCR combo. the screen has a
take the remote and go into the menu and turn off the tele captioning or closed captioning and that shoud clear that up for you
Oct 28, 2009 | Televison & Video
Starview 4 not working
reset to factory default then do a rescan that will fix it
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
Camera will take picture, but the picture is coming out black!!!! Help Please!!!
Dear vera11:
The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot A520 Digital Camera
Black vertical line
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
Dec 30, 2007 | Televison & Video
Tv
I had the same problem with my new TH-50PX60B. I turned the tele on then after 5seconds it would switch off. The standby light would then blink on and off 11 times, pause for a second then flash 11 times. This would continue until the power wasturned off. Note the TV would not turn on for more than 5 seconds.
I solved this problem by turning the tele on and checking the fans at the back. My tele had 3 fans. If one of the fans is not turning, this will be the cause of the problem and the tele will shut down under the Emergency Shutdown System. To clear the fan try blowing on it to free up any dust etc. If that still doesn't work try using a thin instrument (tie wrap etc) to manually turn the fan and free it. Then power off the tele and turn it back on. The tv should work perfectly.
Sep 02, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
66 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
