Question about Ricoh 4506 Copier
Print problem With Ricoh 4506.
My ricoh 4506 is copying fine but when i try and print anything it cancels the job and won't print. It gives an error code of E-310-285522.
Hopefully help maybe out there!
Cheers
Weaver
    Problem Solver:
  • 10 Answers
First of all E-310-285522 is not an error code.It is the Fiery printer number.
Looks like you have enabled password for this copier and ticked accidentally the "password for printing".
Posted on Oct 03, 2009
4 Suggested Answers
SOURCE: Ricoh aficio MP 2510
Where did they get the drivers from?
Posted on Feb 29, 2008
M2Tech1
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
SOURCE: SC 400
Check the connections of the transfer belt unit can be a false contact.
This code disappears when shut off and on the copier.
Posted on Sep 13, 2009
What is the symptoms arises if developers expired ? (For Ricoh aficio mp 1800)
  1. Copies Print like very light and do not print in bold..
  2. Copies prints like shadow.
  3. Does not prints neat job.
Jun 29, 2016 | Ricoh Office Equipment & Supplies
My machine ricoh mp c2352sp displays SC 819. I can't enter to maintenance mode and it couldn't accept the firmware. Any help to solve it!
You have a bad print job coming in... You can prove it by disconnecting the ethernet cable from the unit and reboot the copier, (cancel the print job, that most likley was printed from the internet) -Carl
Dec 08, 2015 | Ricoh Office Equipment & Supplies
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
We have ricoh aficio mp c4000, when i make copies and select colate it goes to the the side tray and separates each one with but when i print and select colate it prints all the documents to the tray under...
You have to set it in the print driver.
When you make print go to properties and select colate. If you do that it should go to the finisher and separate the jobs.
See you!
May 09, 2011 | Ricoh 4506 Copier
I have a Windows printer set up for the Ricoh 12332C. Jobs are sent and clear the queue, but do not print. They appear to be accepted by the Ricoh - they show in the job history log, but they do not print...
Usually the setting of yout network with your copier/printer setting is mismatched so your printer.copier did not understand. What you can do you should check the system setting of your copier/printer and print it out then you should find the driver of your printer/copier in the add printer hardware secrtion in control panel of your computer network . Before you reinstall it , you should uninstall the previous driver so there is no conflict when you reinstall new driver . Try it
Apr 17, 2010 | Ricoh Aficio 1232C Color Copier
How do I cancel a print job sent to the Ricoh Aficio 2018D? It is no longer in my print queue, but printer is still printing all 480 pages
You may have to go to the printer and click on Status or printer jobs and cancel the job from the printer. It appears the printer has the whole job already spooled in memory
Jul 14, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Networked Nashuatec printer cant print after a couple of jobs
try setting on the server for print spooling and check the available memory on printer you can also go to printer properties on the server and get it to print direct to copier
Jul 13, 2009 | Ricoh 4506 Copier
Our 4506 message says load SEF letter
Check if the orientation of the printing document matches to the paper available in the copier's trays.
Load SEF letter: means Load Short Edge Feed letter (landscape).
Good luck and please rate me, thanks.
Jan 30, 2009 | Ricoh 4506 Copier
LAN PRINTING NOT WORKET ON RICOH 1600LE
use an updated driver version for this machine on ricoh-support.com, another solution is using pcl5 driver as this one does spooling at computer and not machine...
Dec 06, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh 4506 Copier Logo
245 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
