SOURCE: Problem with Logitech Cordless Optical Mouse
In the future you would help out if you gave a mode #
However, usually, aside from being dead, their are two good
things to try before despair:
So, to review basically, you want to try and clear away and particles
or build up from the view of the laser (on the bottom of the mouse)
And/or you will unplug the USB base and remove batteries, reboot (let
Windows fully load) - replace the base and the batteries to the mouse,
and finally if no recognition, look for a button somewhere on both the
base and the mouse and hold it down for a good few seconds.
If you still have no joy, please post back here with model and a more specific detail of how it stopped working.
*Last Gem of Knowledge*
It has been known to happen many times, that if you contact Logitech
and explain that your mouse stopped working by no fault of your own,
Logitech will replace the mouse for free
Good Luck
SOURCE: Logitech M-BJ58 USB optical mouse win xp issue
Hello dcipher,
This is due to a missing Windows file called input.inf. The solution is as follows:
In Windows XP, you can use the MSCONFIG utility as described in the following steps:
After extracting the file and restarting, try installing the mouse software again. You should no longer see this error message.
Note: The Windows XP .cab files are stored in the I386
folder on the Windows XP CD.
Should you have any further questions, please feel free to
post them here.
P.S. Before you assign a rating, please
make sure that the issue is resolved or you are satisfied. If not, please post
back as to what you did, and/or any other questions you may have, and I will
try to assist you as best I can. Please do not assign an ‘Inappropriate’ or
‘Thanks for trying’ rating if your issue is not resolved after the first
response itself, as sometimes a bit of to and fro dialogue may be necessary
before we can find a fix or an answer to
your query.
If you find that the solution/answer I provided led you
to, or resulted in a fix, please close the ticket with a FixYa! or Helpful
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Enjoy free
holidays, meals, shopping and more, with mystery shopping!! USA / UK
FREE SOFTWARE GIVEAWAY
Windows Utilities
SOURCE: how to battery compartment for logitech m-raa93 cordless optical mouse?
Should be similiar to this picture: Cordless Mouse Open
The back half of the top of the mouse should slide toward you.
SOURCE: Logitech Cordless TrackMan Optical Trackball connection
you are probably better off buying a new one
unless you are lucky enough to find a used one
SOURCE: My mouse just stopped working. I have a cordless
I would start by pressing the Connect button on the bottom of the mouse, then the Connect button on the bottom of the mouse receiver connected to your computer.
If that doesn't work, try replacing the batteries, then going through the Connect method mentioned above.
Testimonial: "Helpful. I did try the connect buttons. How do I replace the batteries?"
