Refrigerators Logo
Posted on Aug 16, 2010
Where and how can I clean the drain hose on the Frigidare Ref. Water draining in Freezer Bottom
Anonymous
Level 1:
Novelist:
Champion:
  • Contributor 266 Answers
  • Posted on Aug 16, 2010
Anonymous
Contributor
Level 1:
Novelist:
Champion:
Answers
266
Questions
Helped
50669
Points
5
The drain hose runs from the bottom of the fzr to the tray under the fridge. The easiest point to access it is in the fridge compartment there will be a ketch basin (a plastic piece that ketches water from the freezer) with a plastic tube attached to it. This tube is what you want to clean I use compressed air on the tube and to blow up into fzr. good luck
1helpful
Maytag mbf2258Wew1 bottom freezer has ice on the bottom and leaking. Trying to find the drip pan and drain to clean out.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Where does the water drain from on a whirlpool ED5FHGXS Ref? The water collects at the bottom of the freezer section and then runs onto the floor
Leo Ponder
imufo2
Was cleaning refr, and freezer (french door bottom freezer) pulled out water on floor is there a drip pan?
Leo Ponder
imufo2
I have a top freezer Hotpoint refrigerator at a lake home. It's about 6 years old. I've been getting water in the refrigerator compartment. I've tried to clear the hose on the back by...
Leo Ponder
imufo2
Fridge is collecting water under the crisper drawer of my Samsung RF217 fridge, has french doors and bottom freezer. How do I get to the drain hose to thaw/flush it?
Leo Ponder
imufo2
1helpful
I have water leaking on the kitchen floor and also have ice build up on the inside bottom of the freezer. The problem is I can't find the drain tube inside the freezer to see if it is blocked. This is...
Leo Ponder
imufo2
3helpful
Water drip at base of freezer door at bottom!
Have you had a chance to locate the location the water inside freezer? There are many reasons for this to happen I just can not say it would be a defrost condensate drain blockage. Most times it is. Every 8 to 10 hours your freezer defrost and the water is surposed to follow a pipe or drain through the refrigerator to a pan below refrigerator where the warm air from condenser evaporates the water back to the air inside your home. That drain line sometimes slowly becomes blocked and then the drain hole becomes clogged with ice. Once that happens the drain needs to be cleared. I will try to help you solve this so for now I need you to see if water looks as if it came from rear of freezer. Placing photos on Flickr would be great! So tell me where you see it and yes we may need to pull a few things out. This is nothing a few towels, hair dryer hot water and Clorox and a wet vacuum cannot handle. Sea Breeze
1helpful
2answers
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
2answers
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
1helpful
I have water leaking into the ref compartment from the freezer
I would get a pipe cleaner or wire and clean out the rest of the drain hose. also use HOT water down the drain. untill all the water drain thru the hose.
after you get it clear run a wire down the drain and wrap it around the heater .. heat from the wire will keep it clear of ice..
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
