Yes this sounds like the lens unit has gone. You can replace the lens unit itself but not the whole DVD rom unit. This is because each Xbox console holds a special code that pertains to each DVD rom. So if you replace the whole drive you will find that the codes don't match and the Xbox will not allow you to use the drive.
There is however a little trick that you can use on the DVD drive. You have told me that you have already removed the drive from the Xbox itself so what you need to do is take apart the DVD drive, there should be 4 Philips screws on the underside of the drive. Remove the screws and take the top and bottom off to reveal the insides of the drive.
Look for a small white ribbon cable that leads from the lens unit to the PCB (printed circuit board) and disconnect the ribbon cable from the lens unit end NOT the PCB end and then you can take out just the lens unit.
The DVD drive is now ready for you to put in a new or used Xbox lens unit. Once you have your new lens unit just connect the ribbon cable, screw in the lens unit and put the drive back together. Pay particular attention to the connections to the Xbox motherboard making sure they are well seated when you reseat the drive itself. Before re-assembling the Xbox case and screws you can make sure the lens is reading by connecting all leads and power the console up. Pop a game in the drive and it should now read.
Good luck and please post back if there is anything else.
Can you describe the symptoms of the DVD rom as it is now please.
It would play the games fine but then after about 5 minutes it would say that it could not read the disk. After this message appeared it would just say to insert a disk even when there was one already inserted. The xbox would then play dvd's and audio cd's but not xbox 360 games. I have already removed the DVD rom drive from the unit and am just trying to see if I need to buy the exact same one or if i can buy any of the replacements.
So there is literally no way to replace the entire DVD rom drive? If this is true why do they sell replacement dvd rom drives? I have heard that there is a way to do this but perhaps I was wrong. Please let me know.
