Question about Lands Phones
We have a Phillips CD135 portable phone, when we press the recall key and key 6 or 2 to access our answer phone messages, the key just makes three beeping noises and won't let us press 6 or 2 to access them,its as though the recall key is locked. I have looked in the manual but cannot see how to solve the problem ,please can you help? Thanks Ian Wilson
I just unplugged the phone at the mains to try and clear the memory and that has solved the problem.
Many thnaks
Ian Wilson
Posted on May 03, 2008
How do I reset the message on my Uniden DECT 6.0 cordless phone?
Hello Miriam Taylor,
Listening to the message should be sufficient.
Mine wasn't a real message... I fat fingered the
base trying to INTERCOM to my wife's remote.
As I never intended to use my system as an answering
machine... I deleted it too...
If you look really closely at the 1,2,4 & 5 key on the touch pad of each wireless remote the (play) right arrow seen on the base
is adjacent to the 2 key... Press it...
Delete will be an OPTION above the SOFT keys associated with the menu words on your display... (off & message gone).
Then made sure MY ANSWER FEATURE was "OFF".
You will have to read the manual... (RTM, below).
Message access can be accomplished three ways...
at the Base, at any cordless station... and (off premises)
remotely from anywhere in the telephone network.
Hope this helps...
ELSE RTM.
My favorite site for FREE manuals
is manualslib (MUST provide actual model numbers)
No exact matches found Try these results
Uniden DECT 6015 Owner Manual
Amazon com Uniden DECT 6 0 cordless phone Office Products
Carnac the Magnificent
Jun 17, 2017 | Uniden Lands Phones
Retreving calls from another phone uaing my code does not work any longer. I would like to reset the code. Please give instructions. Thank You,
Changing the Remote Access Code The Remote Access Code is preset to 500. You can change the Remote Access Code to any three-digit number from 500-999. DO NOT pick the same number as that assigned to the Priority Calling Code. 1 Press g. The Message Window displays CH. 2 Hold down c for at least two seconds. The system announces "First digit." 3 Press / or ? to change the digit. 4 When the Message Window displays the desired first digit, press c. The system announces "Second digit." 5 Press / or ? to change the digit. 6 When the Message Window displays the desired second digit, press c. The system announces "Third digit." 7 Press / or ? to change the digit. 8 When the Message Window displays the desired third digit, press c. The system announces the new Remote Access Code.
Aug 26, 2011 | AT&T 1725 Answering Machine
My inside screen is broken on my razr v3 and i need to delete the text msgs.
Open your phone Press the Center Key (the key in the middle of the arrow ring) Press the Up arrow key three times (to highlight Messaging) Press the center key Press the left softkey button (to access the options) Press the Down arrow once (to highlight Erase Messages) Press the Center key Press the center key (to access Erase All Messages) Press the left softkey (to confirm Yes Erase All Messages)
All your text messages are now deleted.
Mar 25, 2011 | Motorola Mobility RAZR V3
My mobile phone restart self
FORMAT YOUR PHONE
1. Make sure your phone is fully charged.
2.
Backup your contacts list and personal files to MMC memory card (if possible).
3.
Switch on your phone.
4.
Press and hold these three keys together:
* Red dial key,
* Sharp key (#)
* One key (1)
5.
5
Press the power on/off to swtich off the S60 phone. Do not let go the three keys until you see the "formatting" screen displayed
6.
6
Wait a few minutes until the format is complete. Your phone will now be at its original factory settings
Method 2
1.
Before you format your phone, make sure you back up all your ringtones, SMS and picture messages and most importantly yout contacts. You can use the Nokia PC Suite to do this.
2.
Press Red key, select disconnect.
3.
Once you've done this, key in *#7370# *#7780# . It will immediately prompt you to restart your phone.
4.
Select 'Yes' and the phone will restart after formatting. It takes about 2 to 3 minutes to complete the process. Also ensure that your phone is well charged before you format.
5.
5
Now restore all your ringtones, messages and contacts and you once again have a fresh OS.
Nov 23, 2010 | Nokia 5200 Cellular Phone
Format
2.
3.
4.
* Red dial key,
* Sharp key (#)
* One key (1)
5.
5
6.
6
Method 2
1.
this.
2.
3.
restart your phone.
4.
5.
5
OS.
Nov 23, 2010 | Nokia 6300 Cellular Phone
Cant get remote access working Binatone Symphony 2210 cordless ph
If you have set up the TAM settings correctly then it seems to be a fault with the machine. I've set up my TAM settings with new pin and I still can't remotely access the messages.
Make sure you are pressing the * key before you enter the default code (as far as I can recall).
Apr 05, 2010 | Lands Phones
Philips CD135 Twin cordless
press bottom left button and then hold down 7. display will show 0-0 to indicate its turned on. 2 to read messages. 3 to skip to next messge. 4 to record your message. 5 to listen to current welcome message. 6 to delete messages. 7 to activate answer machine. 9 to deactivate ans mach. 0 to record internal memo. To use any of these functions bottom left button must be pressed first.
Apr 07, 2008 | Philips 2252 Twin Cordless Phone
Philips model cd135
Hi there Fred
Here are links to user guides for your unit. Good luck, thanks for using FixYa
http://www.p4c.philips.com/files/c/cd1302s_73/cd1302s_73_qsg_eng.pdf
http://www.p4c.philips.com/files/c/cd1353s_05/cd1353s_05_dfu_eng.pdf
regards
Graeme
Mar 15, 2008 | Lands Phones
Lands Phones Logo
129 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
