My NEC Versa E2000 wont even go in to the log on menu. Just the black screen that asks how you want to start the computer (Windows, safe mode etc) I have tried all of these and it still reloops back to this screen. How do i fix this problem? cheers.
Turn on computer & quickly double click on F2 to set full start mode in setup.
Posted on May 03, 2008
My nec versa e2000 always reboot after power up for a few minutes
It would seem that a driver may be the cause which is loading during startup.
Suggest booting into safe mode by pressing F8 before laptop boots into Windows and then use msconfig to select the drivers to load at boot time.
Keep eliminating drivers until you locate the one causing the problem and then remove and check for a later verison of the driver.
Mar 25, 2014 | Computers & Internet
Wont start i go to safe moode it dont work f11 asking for pass word
Which operating system ????.....
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Oct 14, 2013 | Medion M3 Composer 5100 PC Desktop
Change password
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
I would like the manual for the NEC Versa E2000
NEC does not offer PC manuals online :(
Jul 08, 2011 | Computers & Internet
My sisters Acer Aspire 5810TZ has a virus but when we go to log onto her laptop the screen goes black and wont let us do anything to try and get rid of the virus. What should we do.
Try booting into safe mode first. During boot up press F8 a few times, you should get a safe mode menu to; start windows normal, or safe mode, chose safe mode an see if that will get you logged in.
Oct 12, 2010 | Computers & Internet
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Forgot system password to restrict internet access
Log on to your computer with safe mode
Steps
1. Start your computer
2. As soon as you see the first black screen when the computer starts , keep on pressing F8
You will see advanced options menu
Select " Safe mode with net working"
Now your computer will give you an option to log in with the administrator username
You need to log in with Admin and then goto control panel and change the password for your username ...
If this does not work then plz reply back stating the Operating system you have like windows XP, vista , 98 , 2000 etc...
Jun 09, 2008 | 2wire 1800HG Router (RG1800HG00)
Nec versa e2000 laptop
Joelmar, you are incorrect. This model was also sold with xp, I'm typing this on one. If you still have the original Hdd and have not formatted the recovery partition, boot up the laptop whilst holding the f11 key. This will start NEC recovery and allow you to reinstall the system, drivers included. Back up first!
Jun 08, 2008 | Computers & Internet
Windows login password
Steps
Jun 04, 2008 | Toshiba Computers & Internet
NEC Notebook
You have to scan the drive(s) for more virus.
If u recently install any new hardware disconnect it until u finish load windows service pk 2.
Or try again re-installing windows remembering not to plug in any cards etc.
thanks
Jaywizz
Nov 19, 2007 | NEC Versa FX Notebook
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
