Question about Intel Dot Station (INTC300AIO) PC Desktop
Character keys How to use the number keys and the other character keys.
THANKS MY PROBLEM HAS BEEN SOLVED BY USING STEP 1ST
Posted on Jun 01, 2008
  • 652 Answers
There is a NumLck/ScrlLck (Num Lock/ Scroll) key on the top row right side of your keyboard. If it will be on, then you can use the keys as Numeric and if it off then it will work as character.
To toggle between on/off you can try the following.
  1. Press Fn + NumLck/ScrlLck, if it not works then do step 2.
  2. Press NumLck/ScrlLck, and try if it not works then do step 3.
  3. Press Shift + NumLck/ScrlLck.
Please post your feed-back.
Thanks
Iqbal
Posted on May 01, 2008
  • Iqbal Husain
    Iqbal Husain May 01, 2008
    Sorry friend my solution was for Lap-Top.
Keyboard not functioning
It may be a fault in the keyboard driver or in the keyboard itself. However if the character you need is not available on the keyboard directly it is possible to get any character by using the ASCII char code entry method. First off search the internet for a ASCII character number associating table (for a chart I like best, check here http://michaelgoerz.net/blog/2008/09/ascii-table/ascii.gif) now on this chart you have to use common fonts (IE: Ariel, times new roman, ect.) because some of the TTF fonts do not have all the characters in them available.
Now to practice using the characters, load Notepad and find the character you want to display from the chart (note: the number like 000d and 00h actually means 000 decimal and 00 hexadecimal, only use the number with the "d" after it with this method), on Notepad, after you pick out the character you want to display, press and hold the ALT key, and on your keypad (on most keyboards it is on the right side and resembles a calculator type keypad) while holding the ALT key down enter the number of the character you want to display (do not include the "d", only the number) then release the ALT key and that character should display for you in Notepad. Almost all standard fonts has the regular characters and some has the extended characters, you will have to check to see if the font uses them by trial and error. this method is a long lost forgotten means of putting characters into your documents which does not have keys on a standard keyboard (most standard keyboards only have 101 keys so this is the only way of using all the 255 character available in common fonts).
This is a built in function of all computers that uses Microsoft OS's and even DOS, HDOS, EDOS, (well all the DOS's), and you can use them anywhere you can type anything from your keyboard, (emails, letters, databases, spread sheets, etc.) if you can type from the keyboard to any program you can use these characters in this manner.
I hope this help you out!
Aug 15, 2013 | E-Machines eMachines Desktop PC
WE HAVE A SHARP ER-A610 CASH REGISTER WE WOULD LIKE TO CHANGE THE ITEM LABEL FOR EACH DEPARTMENT KEY BUT DON'T KNOW THE JOB # AND PROCEEDURE FOR DOING IT I DON'T HAVE ALL THE PAGES OF THE MANU
Sharp uses a 3-digit ASCII code for each character. The ER-A610 manual has a table of the codes, but if you've lost that part of the book, you can find ascii tables online, like this one:
http://www.ascii.cl/
Note that many of these show 2-digit codes; add a leading zero to those, so A is 065, B is 066, etc.
the 00 key on your ER-A610 has a special purpose here - it is used to enter each character's code, so to spell FOOD you'd enter:
070 00
079 00
079 00
068 00
where each of those double-zeroes is the double-zero key, not just two zeroes.
You need to know the number of each department you need to change. If you're not sure what order they're numbered in (It's completely customizable, so don't count on them being in order, unless you're sure.), print out your current department programming:
(In PGM1 or PGM2 mode)
1100 @/FOR CA/AT
will print out all the depts. CA/AT is the Cash key at the bottom-right corner of the keyboard. It stands for CAsh / Amount Tendered, which isn't exactly obvious, so some folks relabel it.
Note that on the tape you printed, the name is printed below the dept. number.
Now we're ready to start. In PGM2 mode, enter:
2114 . @/FOR (Is the decimal point after the 2114 visible here?)
[dept. number] @/FOR [character codes] SBTL
(etc. until done)
CA/AT
For [dept. number], enter the number on the keypad, not by touching the actual dept. key.
[character codes] is the sequence of 3-digit codes and 00 key presses, like the FOOD example above.
If the departments you're changing are sequential, life is a little easier. When you finish Department 6 (for example) by touching the SBTL key, it will automatically count up to 7. You can do a series of depts. by entering the first of them as above, then after using the SBTL key, go straight into the character codes for the next in line. Continue this way for as many are in series. You can jump ahead or back at any time by with [dept. no.] @/FOR and keep going from there.
SBTL in all the lines above, means the key that normally shows your subtotal including tax. It might be labeled #/SBTL. The MDSE SBTL key won't do the trick.
If you use PLU's in you register, their names are programed exactly the same, except that instead of starting with 2114, you use 2214. Simple, no?
Jan 11, 2013 | Computers & Internet
I am trying to return my tower to factory setting.It keeps asking for a25 character number.
Are you sure you're back to factory settings? That 25 character number sounds like the Certificate of Authentication (COA) key for the Operating System. Look on the side and back of your computer for the COA Sticker. It tells you what Operating System you have and it will have a series of 5 letters and numbers (25 to be exact) that is the key to validate and activate your operating system.
May 16, 2012 | E-Machines etower 500ix PC Desktop
On my computer it says i have microsoft word but it says i need a 25 character product key i dont know what that is
The 25 character product key "they" want is the number that came with your copy of MS word, or Office, more to the point. You enter this "Key" and then ya can use the software. It is generally on the sleeve of the cd cover or the box etc.
look at this http://aboutonlinetips.com/wp-content/uploads/2009/11/product-key.png
Jan 20, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
GENERIC KEYBOARD ALPHA KEYS DO NOT WORK PROPERLY
Numbers do though? If this is the case, try a different keyboard. If the keys are outputting different characters, then you should check the character map, oh wait that should only apply to alternate Operating systems, hum, then again XP does have that accessibility thing... Bottom line: If a different keyboard with the same connection works, just e-waste/recycle/trash that keyboard...
Mar 08, 2009 | HP Pavilion a705w PC Desktop
Cant conect to internet
  • Wii Error Code 51300 - 51399
  • This error is caused by the Wii being unable to connect to the access point.
    To solve this error :
    Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
    If your router is using WEP encryption
  • Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
    If your router is using WPA encryption, the Wii is compatible with :
    WPA - PSK(TKIP)
    WPA - PSK(AES)
    WPA2 - PSK(AES)
    If your router is using MAC filtering, ensure the Wii MAC address has been added to the list of approved MAC address on your wireless router settings
Dec 27, 2008 | Computers & Internet
Numbers are locked - will not unlock
Not a solution! I am 84 years old and cannot afford to invest any more money in your equipment that has let me down. I had the same problem on a LapTop and by holding down the Fn and scroll keys it was solved. Will you help me or not? RJ
Nov 19, 2008 | Computers & Internet
Cannot find the serial key to the movie box studio instal disc
Hi yellowbret,
Sometimes the serial number is part of lager alpha/numeric character string. When tried to install and it asked you for the serial, look to see how many characters you can type into each text field. Its usually limited to amount of characters in the number. Once you have that information see if any of the numbers you can find match the total character input for the requested serial number. There is a series of numbers that are etched on the back center ring of most cd's, however, I'm not sure what they represent( I bet someone on here knows the answer to that). You may need a magnifying glass to read them. There several on-line serial key finder utilities you can explore. I hoped this helped.
Thank you for using FixYa.com
Sincerely, cyyyd7
Oct 09, 2008 | Pinnacle Computers & Internet
I need an 8 character referral key for microsoft office professional 2007
I need an 8 character referral kay for microsoft office professional 2007
Oct 01, 2008 | Compaq Presario 5000 PC Desktop
Intel Dot Station (INTC300AIO) PC Desktop Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
