Would not dry clothes to original dryness. Now drum is making a whinging noise at the drum spin as though its catching on something every time it rotates. Also made a very loud clattering noise as it spins.
I had this same problem. The drum spins on two small wheel which with the help of the drum belt support the drum. The wheels or their brackets may be broken and need to be replaced. These are accessable by taking the back off the dryer. Best to take the old/broken ones in to insure you get the exact replacement.
Posted on Jan 23, 2009
Dryer making chirpy squeaky noises then it stopped. Noise was intermittent
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Mar 10, 2015 | Dryers
Forgot to put the lint trap back into LG Ventless Dryer DLEC855W. Clothing might have gotten stuck inside. Dryer now making grinding noise and drum is moving slowly. Is it time to call a repairman?
The filter simply allows the dryer air to pass through and trap the lint so it will not collect in the exit tube or on the outer vent parts. If anything, the clothes inside the bin will just spin around and be there when you finish. The noise inside the dryer could be from something that was in the pant or shirt pocket and was floating around.
Mar 01, 2014 | LG Electronics DLEC855W Electric Dryer...
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
Machine is filling with water but the drum wont turn or spin
MOST LIKELY THE MOTOR IS SHOT OR THE BELT AROUND THE DRUM CAME OFF THE DRUM
Feb 06, 2013 | Washing Machines
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
Drum is sparking when spinning the clothes
Sounds to me as though the main drum bearings have gone and the drum is catching the internal parts.
I f the drum is turned by hand and it feels rough or is noisy, then it is the main bearings.
Sep 24, 2008 | Creda W120VW Front Load Washer
LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Nov 18, 2007 | LG DLE2532W Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
