Question about Canon PIXMA MP130 All-In-One InkJet Printer
Canon MP 130 printer
I have a new computer and the printer won't install or print from the computer
  • Damen Wong
    Damen Wong May 11, 2010
    Did you install the printer?
    President:
  • 1,944 Answers
Has your problem been solved?
Posted on May 03, 2008
  • 655 Answers
Suzi 39,
  • Your printer driver must supported for your Operating System on your computer. If you don't have driver for your Operating System. Click Here. Goto this page and download driver for your OS.
Thanks
Iqbal
Posted on May 01, 2008
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My PIXMA MP 130 is not printing colour. The cartridge is new and genuine Canon. Please help.
Check to see that the "Greyscale" tab hasn't been set, and it is set for color printing this is in printer properties. Steps : **click on print **then a box will come up and select advanced options
and fine where it says print grayscale
** then select the color
May 30, 2011 | Canon Office Equipment & Supplies
I can't connetc mx310 to my new computer. The computer is running windows vista. Do I need to download a seperate software ?
The printer drives varies with OS, even if the printer is of the same model. So goto canon website and specify your printer model and OS, download appropriate drivers and install it in Vista. Then you are good to go.
Mar 28, 2010 | Canon PIXMA MX310 All-In-One Printer
My canon mp 130 printer will not print color i
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I have a canon MP 130 printer that is not printing. I have put in new ink cartridges, replaced Print Head, and reset the waste ink absorber counter. None of this worked. The printer does not print at all....
That printer has no parts or repair, during warranty Canon would only replace the entire printer. After the warranty runs out, you just buy a new printer. It sounds like the purge or cleaning unit is not working, but no parts are available to fix this model.
Feb 18, 2010 | Office Equipment & Supplies
How do i open the printer to get to the waste
Getting to the pads won't help, they are under the print engine and cover the whole bottom of the printer. The cost for a new set is around $10.00, but after changing you need to get to the service mode to reset the counter, and only Canon shops can do that.
Jan 31, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Cartridge jammed
my canon pixma mp 130 says it has a cartridge jammed...Ive tried new cartridges but still get the same situation
Aug 17, 2008 | Office Equipment & Supplies
How do I change ink cartridges on a canon pixma mp 130?
just open the front door(your printer should be power on) the cartridge carrier will come and stop in the middle, just take out the cartridge and install the new one
Jul 21, 2008 | Canon Office Equipment & Supplies
Printer Installation
if you have driver cd then just pop it in the cd-rom it will auto run.then u select your region then give easy install.after that it will ask to connect the printer to pc just put the powercord to printer and the usb cable from printer to pc and swithch it on.click next after reading the instruction.you have to install the cartdridge to the printer before printing.
Apr 05, 2008 | Office Equipment & Supplies
Canon printer double printing and nor lining up top and bottom of letters
I had a similar problem with my 8500. I downloaded the latest driver from Canon, and the problem seems to be fixed.
Feb 05, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
46 people viewed this question
old marine
old marine
