Nope it isn't defective. You don't mention from your question if you bought a LCD type or the CRT type of monitor. But I think you bought a LCD monitor right? My question here is where do you connect it? From the graphic card or in the onboard vga of your motherboard? How old is your graphic card/onboard vga? That is always the problem of an old graphic card because it can't release more pixels that's why it says out of range. Connect your old monitor it will work because it can support your graphic card/onboard vga. Buy a new graphic card with a specification that will suit to your motherboard and to your new monitor before it become a money waste
I see that you are having a check input error on the Monitor/LCD that your are connecting to your Dell tower, please see steps below.
On your HP 2310E make sure that your HP is set to the input/source that you are using and make sure that you only use one type of video cable for the issue.
I see that you mentioned that you have a VGA cable and a DVI cable, you can only use one type of cable for a video connection.
VGA would be the Blue tipped cable connecting to the tower and going to the LCD monitor.
DVI this is a black cable connecting to a white port much bigger than a VGA port and is rectangular in shape unlike the VGA
and on your LCD monitor check the input type to see video from the tower.
everything seems to be OK you just need to change the input of your LCD monitor for the video to show up on the screen.
also if you are using HDMI for the video u will need to change the setting of your Audio and set HDMI as the Default to have Audio come out from the HDMI connection together with video, the HDMI viedo will automatically be detected as long as the LCD monitor's input is set to HDMI.
I hope that this will able to help resolve your concern.
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
Used ur computer VGA monitor cable.Connected to the computer video card port and the other side of the VGA cable connected to the LCD tv VGA video port.This will work fine too.
if your monitor came with a disk try installing the drivers again you might still have the drivers for the previous monitor you had with your system if not try going to the manufacturers website and getting the drivers and install them
Sounds like the PC has too high a screen resolution set for the TV to handle Re-connect PC to PC monitor , change display resolution to 800 x 600 (right click desktop, properties, settings, slider marked "screen resolution" to leftmost side, save settings. connect PC to TV, TV should be able to display PC data now. Go through same procedure with PC connected to TV, move slider to 1024 x 768 posn. (depends on TV model as to what it can cope with) - *apply* this setting & see if TV is able to display at this resolution. If it is, desktop will appear - if not, you'll get the warning box generated by the TV...don't worry, in 15 secs, the PC will revert to the old (working) setting.
Depending on the model of video card you have, it would be either the VGA or the DVI connector. Many new cards have one of each or 2 of either VGA or DVI.
Many newer LCD monitors can to plugged into either connector, as they have connections for both. There are adapters that will allow VGA to be plugged into DVI as well.
If you computer does not have multiple outputs, you can only plug in one monitor, however.
There is also a 9 pin VGA connector, but they are a lot less common - I'm guessing this is what you have.
Is the video cable hard-wired into your monitor or is it connected via a plug? If it's a plug, is that a 15 or 9 pin? If it's a 15 pin, then all you need to do is buy a new 15-15pin VGA cable.
If it's hard-wired, you'll need to buy some sort of adapter. These are available and don't cost much either, but you might need to try a more specialist computer store to find one.
