Question about Olympus Camedia C-730 Digital Camera
Lense error I get a lense error message. My lense is shut open on my Olympus 730 and the camera keeps shutting off
AWESOME. IT WORKED
Posted on May 19, 2008
    Scholar:
  • 89 Answers
I had the same problem with my Nikon coolpix camera. Fortunately, I found a very strange solution from google.com :
"Hit the camera on the palm of your hand a few times (hit the side of the camera , not the lens). Try it slow at first, if it does not work try to hit it harder (but gently). "
I'm not sure if it will work with an Olympus camera and if this is a permanent solution ( a co-worker borrowed and lost my camera after a few months!!) . Also, there is a risk that you will permanently damage the camera. If your camera is under warrany send it for repair.
Posted on May 01, 2008
When you turn the camera on the lense opens and the camera shuts off with the lense still open. I turn on again and the lense closes and then shuts off.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 30, 2011 | Pentax Optio 60 Digital Camera
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
When I turn on my Camera, the screen turns blue and say Zoom Error in red writting, and it wont turn on, and the shutter will not shut!
This happens du to friction in the movement of the lense assembly. Did you happen to drop it in sand or on hard surface. If the camera if exposed to sand, just the cleaning of the lense assembly,( gears and the barrels) will solve the problem. But, if any damage is there then the complete lense unit needs replacement.
Jul 17, 2008 | Olympus Cameras
Error message 5e02
Turn on your camera, when the lense is opened, hold it till the blue screen appears, extend the lense to his maximum forcing it a little bit then when you turn off your camera, the noise won't be here. Turn on again your camera and hopes it works. I tried it on my camera, works well at the first try then again the error, i did it twice holding the lense when you turn it on, then it worked perfectly.
Hope it works for you.
P.S : my english isn't well but i hope it helps.
Oct 17, 2007 | Olympus Stylus 710 Digital Camera
"Cover opened" error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 14, 2007 | Kyocera Finecam L4V Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Olympus Camedia C-730 Digital Camera Logo
71 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
