Question about ASUS P4S800D-X Motherboard
Memory hi, i install 4G of ddram , but i receive only 3328 M . What i'm do?
    President:
  • 2,351 Answers
Hi maiger,
Each of the 4 memory sockets on P4S800D-X can support 1GB memory module, so the M/B can support up to 4GB memory max. Please note that if you install four 1GB memory modules on P4S800D-X, the system may only detect 3GB+ (slightly less than 4GB) due to ICH5 resource allocation.
Mike
Posted on May 01, 2008
Hp pavilion g7 does not recognize all 8g memory
If only 3GB is recognized it isn't a 64bit OS.
Jul 06, 2013 | Computers & Internet
I have asrock p4i45 can i put ddr3 or ddr2 2gb ram
hello rkr phoenix, u can only use DDR2 on this motherboard, this was type motherboard with processor socket 478, and this type only have two choice, SDRAM or DDRAM, on asrock p4i45 can have DDRAM socket. hope this useful, regards.
Aug 22, 2011 | Computers & Internet
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
How do you "turn on" or make newly installed memory work on a laptop computer
upon boot-up the system automatically detects the amount of memory installed, if for some reason the amount of memory installed it's not the same with the amount detected there might be a problem with the placement of the modules or the system simply does not support either the module, quantity or type of memory. (if you're talking about system memory eg. SDRAM/DDRAM).
May 25, 2010 | Dell LATTITUE C- SERIES FDD MODULE 1.44MB...
What steps are needed to upgrade my memory. I have a etower667ir with ramsd64mpc. I want to install 2 128mb sdram dimm pc100. what do I need to do?
First download a system analyzer fromwww.belarc.com and use it to check what is the maximum Ram that it can accommodate. If it will take just make sure you-get Non-parity ram when you buy the sticks. please note that SDram is more expensive that DDRam, but cannot be substituted.
Jan 06, 2010 | E-Machines etower 667ir PC Desktop
How to jumpe SDRAM to DDRAM
according to my research- this mobo will support 2GB ddr400/333 sdram- 1GB in each slot. don't think it will support ddram. don't know if you can mix 400 and 333 bus speeds. probably can, but put 400 in slot 1. not sure ddram will even fit in ram slots!
good luck!
Sep 24, 2009 | EliteGroup nForce3-A Motherboard
Diff between SDRAM and DDRAM
Only one of those will work in any computer. Synchronous Dynamic Random Access Memory is older and slower, Double Density Random Access Memory is faster and DDR2 is newer. The notch in the connector edge will not match the RAM slot if you have the wrong one. Also the DDRAM has various speeds to match the bus speed of the motherboard so designators like PC2100, PC2700, PC3200, etc. are important and correspond to 266MHZ, 366MHZ, 400MHZ, and so on. Notebook use SODIMM RAM and have the corresponding DDR, DDR2 designators but still have notches that must match the slot. When you buy RAM just provide the model of your computer as each manufacturer has numbers that are all designed to confuse it seems and there may be no chance of exchanging the memory after you open the package. Steve
Oct 14, 2008 | Compaq Presario 700 470024-192 Notebook
Jetway MoBo: 2 x 1GB Samsung PC2100 appearing as just 1GB (2 X512MB)
Your post indicating that you are moving up from SDRAM to DDRAM shows that your motherboard is capable of either type (having both type of slots) and therefore would have been a few years old. Having said this, then your MB would have the very early version/compatibility of DDRAMs where/when 512 then was the highest readily available memory.
As most Taiwan manufacturers, Jetway would be publishing specs that are a bit just over rated in terms of their product performance unlike Asus, ABit, AOpen. Additionally, most have been known to be using the same manual for several versions of the motherboard. A similar looking motherboard can come in several versions such as those with internal video while another is an AGP slot; one versions may or may not have built-in Ethernet port. In the same token, a version may have 2 X SDRAM slots + 2 DDRAM slots or 4 X SDRAMs or 4 X DDRAMs. Again, we are talking of the same model number of the motherboard but different versions/revisions.
2 G would be right for the 4 X memory slots versions (at 4 X 512) but since you have the 2 + 2 (2 SDRAM + 2 DDRAM), maximum would only be 1 Gb (2 X 512).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 03, 2008 | Jetway V266B Motherboard
Where to get memory upgrade installed
open the side pannel then you will see the ram installed in slot, just put the ram module into the empty slot and gently push it, the latch in the side of the slot will close with a click sound
May 14, 2008 | Computers & Internet
ASUS P4S800D-X Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
