Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier ducted heater
  1. The units fans all work when the unit is on, but the burner's don't ignite to warm the home, please help kids ar nt happy 2yr old girl and 8 yr old boy
  • 828 Answers
Ignition system may be your problem. Call for service.
Posted on May 01, 2008
Main burners in my old utility gas heater will not ignite
A common problem with these are the safety limit switch trips, either because the fan did not come on and over heated the unit, or the unit got shut off while in heat mode, causing the switch to trip. These are usually located around the top/side of the unit heater behind a small access panel. It should be resettable by pushing in the small button in between the two connections. Hope this helps!
Dec 07, 2013 | Mr. Heater MHU45NG
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Pentair minimax nt explosive ignition
Problem is an obstructed gas oriface. The burners light from the burner closest to the pilot assembly out like a dominoe effect. The explosion is because the gas has to make its way over to the pilot from a further burner thus filling the firebox full of gas before it ignites. This blockage is most commonly from a spider web inside the oriface itself. Pull the burner tray, remove the orifaces from the tray and look through each one cleaning them out with a toothpick from the backside. The orifaces should be threaded on the gas line coming off the gas valve (looks like a silver box inside the front panel)
Feb 16, 2012 | Pentair Minimax NT Heater
Rheem warrior glass serial num r0296b08705 model
You need to first determine if the burners light or not.
As long as the unit wasn't run with a dry tank the unit should not have been affected by continuous water running, unless it got hot enough to damage the thermocoupler which is an easy replacement. That is the part that your pilot/ignitor warms so that the gas valve will open the gas line to the burners.
Aug 12, 2011 | Rheem Single Water Heater Thermostat
Heater will not ignite.
Try replacing the ignitor.
May 15, 2010 | Pentair Minimax NT Heater
Home is not warm enough
This sounds like one of two issues. Either your fan speed is on high and needs to be adjusted to low, or if that is done then the issue lies in the duct work. either the duct work or plenum ( your air ducts connect to) is leaking air and the hot are is escaping threw holes. Another issue is rats or mice eating the duct work. Also check your thermostat to make sure that the fan switch is on auto and not on
Jan 10, 2010 | Heating & Cooling
I have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Nov 24, 2008 | Pool & Spa
Burners wont ignite
does unit have thermo-cupling
Nov 23, 2008 | Carrier 52PQ307 Wall/Window Air...
No heat, trouble shooting light has continious flash.
There is a vacuum sensor on most units tied from the exhaust gas fan to the sensor. Does the unit try to start? If the unit's exhaust fails to pull the switch it will turn off after about 30-45 sec after starting. "IT" thinks it's not exhausting and stops to keep from overheating. Do you have this exhaust fan and rubber hose to sensor? Can you see if that fan is turning on start?
Nov 08, 2007 | Goodman GMS90703BXA Heater
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
67 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
