Question about HP Pavilion dv6000z Notebook
I was operating windows vistabut corrupted. right now dvd writer is not working. i want to load windows xp using pendrive.how to load windows xp using pendrive
  • 36 Answers
For loading windows xp please use a usb ODD or clean the laser of the cd rom.
Posted on Aug 16, 2010
SOURCE:
How to format desktop having windows xp installed on it the dvd writer is not working can i format it from usb pendrive
You would need to create a bootable USB stick, and then use tools installed on it to format your drive. full instructions Create Bootable USB Flash Drive
Aug 24, 2014 | Microsoft Windows XP Professional
Tip
Corrupted files in xp?
This tutorial has been made so people that are having problems with corrupted files, can learn how to fix them easily.
// Required //
- Windows XP operating system
- Windows XP cd
// Right to the tutorial //
- Place the xp cd in your cd/dvd drive
- Go to start
- run
- type in 'sfc /scannow' (without the ')
Now it should all load, and fix all your corrupted file on windows XP
on Aug 02, 2010 | Computers & Internet
DVD Burner Not Found
male sure the laptop has teh burn dvd capability cause it can be just a cd writer and dvd rom ..and in this case it is explainable why its giving the error ..
If you are sure you have a dvd writer ...than be sure you select it in the options of the burning software you use..
and 3rd ... if your writer is corrupted ..try to go to device manager ..(click right on compuer select properties..and device manager..) in there look for dvd writer...click right on it ..and select update driver...If the disk is not present click right on computer ..and select scan for hardware changes...If the writer is deactivated this will bring it back ..Than update its driver and be sure it's not in yellow cause this means the driver is not the correct one ..
If no action will correct this ..and still makes the same ..than I suggest to reinstall the operation system ..and this way you will eliminate the possibility that a bug corrupted it ...and in case it still not working you have to consider replacing it ..but not before trying a operation system reinstall ..cause there are viruses that attack the disk drive's driver ..and this is the only fix .
Nov 29, 2011 | Sony VAIO VGN-CR220E/P Notebook
My dvd/ cd writer can not read any type of cd and now I can not reboot my laptop.
You should make a bootable Flash drive.
You will just click on bellow the link and follow all the step.
http://komku.blogspot.com/2008/11/install-windows-xp-using-usb-flash-disk.html
After making the bootable pen drive go to bios setup>Restart>press F2/F10/Dell
Boot from usb.
There are many type of bios setting.
Follow these .
http://www.computerhope.com/help/phoenix.htm
http://www.pcbuyerbeware.co.uk/BIOS.htm
and also set you HDD piority ,Now note it ,Usb drive will be 1st Hdd drive(usb pendrive)
Hope it will solve your problem.You can also repair or change the cd/dvd writer through folloing steep.
Or can do it from this link.http://komku.blogspot.com/2009/09/wintoflash-guide-install-windows-xp.html
Hope it will help you.
Jan 07, 2011 | HP Computers & Internet
Which dvd burning programme is best with windows xp
Access: http://www.MajorGeeks.com
Search for 'AShampoo Burning 6'.
Download this *FREE* software for creating/writing CD/DVD/Blu-Ray disks.
Install it.
Oct 22, 2010 | Microsoft Windows XP Home Edition Service...
Dvd writer does not write or read any dvd on hp pavillion a1230n windows xp operating system
Try booting from the disc drive with a windows CD. If it does work, then try uninstalling from devices in windows, then scan for hardware changes and re-install. If its still not working I suggest doing a backup of your files and re-install windows, a corrupted registry may also cause this. If trying to boot from CD does not work you will need to replace the DVD drive
Dec 02, 2009 | Computers & Internet
Dvd Driver
Hi elyse09,
If your PC system is not a notebook than the DVD writer will fit in to your system. This DVD writer burns a variety of DVD's at different speeds depending on the DVD disks speed & CD-RW's as well. Windows does not need driver for DVD/CD writers. This DVD writer is also a DVD player. It comes with software that allows you to use the internal laser to write labeling onto the disk. It will take time to learn how this is done but for the money its at the top of its class.
Click on the linprovided;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4323576&CatId=89
Mike
Mar 31, 2009 | Intel Computers & Internet
Pendrive Problem in windows 98
you have to use xp os.because windows 98 is tatally back dated. thats why its not opening. or you can check it into another xp os. computer if it is open then your sure that windows 98 is not supporting, or if it is not open then your pendrive has some problem.
Mar 17, 2009 | Microsoft Windows 98 for PC
Can i install xp on pendrive ?
  1. Put the cd with xp on it in the cd rom
  2. plug your pen drive into your computer
  3. open "my computer"
  4. drag and drop the cd to the pen drive and it should copy the files to it.
Let me know how it goes.
Jan 05, 2009 | Microsoft Windows XP Professional
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
