39 Other Users Have The Same Problem - Continued
Comment by p1nmg, posted on May 04, 2009
My friend's L100 was also dead after about 2 year's operating. Replaced the 3 capacitors as suggested in this thread. All sorted - many thanks.
Comment by BasKrie, posted on Apr 02, 2009
I'm facing the same problem with the acer aspire L100.
I am trying to desolder the caps, but the solder won't even melt a little.
Could someone tell me wat kind of soldering iron you use?
Comment by MartinKW, posted on Mar 02, 2009
My wife has the L100 and I have the L3600. Last week her L100 froze as it had done a few times recently. When she plugged the power back in all we got was a strange buzzing.
I did an internet search and found this page. I phoned a friend, and described the problem and the solution (new capacitors) as related on this page and he said he'd had a similar problem with a Dell recently.
This weekend, he arrived with his soldering iron and three new capacitors to replace the dead capacitors as described in the solution below. The three were all bulged on the motherboard. He found it difficult to solder and had to use a high temp setting on his soldering iron, but in the end he got them swapped out. So far, after 36hrs of continuous running, it is still working. Hopefully this has cured the problem.
Looking at the internals the door probably doesn't have much affect as the only openings I can see internally behind the mesh are actually always open to the air flow even if the door is closed - the door doesn't appear to block any internal apertures although I suspect it would help not to have the door acting as an insulating layer of trapped air. There was a fair amount of dust in the side screen (or top if standing vertically) and on the fan (all blown off now), and the location of the single cooling fan is close to the main side screen so there is insufficient air flow being drawn over the rest of the unit, plus with the h/d and DVD unit in there, there's little chance of a decent air flow without adding some additional air flow. However, given the better quality capacitors now fitted let's hope there won't be a repeat.
Also, anyone know why the L100 fails to come out of "sleep" mode? All I get on the L100 is a fine line of colour at the top of the screen, and I have to reboot the unit.
Comment by DOUGVIANE, posted on Feb 24, 2009
MY ACER L100 ALL OF A SUDDEN JUST SHUT DOWN. THE POWER UNIT WAS OKAY. SUSPECT IT IS THE MOTHERBOARD TOO, FROM OVERHEATING . I HAD THIS UNIT FOR MY SON & IT'S ALWAYS BEEN IN THE VERTICAL POSITION BUT DOORS WEREN'T OPENED AS THERE WERE NO INSTRUCTIONS ABOUT IT. MY MACHINE IS ALSO OUT OF WARRANTY SO I'LL TRY TO POKE AROUND AND LOOK FOR THE OVERHEATED CAPACITORS.
Comment by angelladixon, posted on Feb 12, 2009
Wow. There should be a way for everyone to get a refund for this piece of junk. I have an Acer laptop that works pretty well. This desktop version was bought for my children and we have had nothing but problems with it since we bought it and now it will not come on at all.
Comment by philkarlin, posted on Feb 11, 2009
Same problem on L100's. Called Acer, for out of warranty repair they wanted $300.
Comment by pightle, posted on Feb 04, 2009
Steve...fed up with Acer!
Oh Dear, I have now had the same problem on 3 client pc'c AND my daughters!...wll try the Capacitor fix and report back....Acer are no help atall, even though 1 of these pc's has been back twice (under the warranty period) for the same fault! they couldn't care less.....and these machines are still for sale in PCWorld!
Comment by carlosandjoy, posted on Jan 23, 2009
Same problem. Shut it off last night and nothing this morning. is 17 months old. Not a total loss, the fan and dvd still works.
Comment by johnhk, posted on Jan 19, 2009
Similiar! Push the Start Button, no power, no LED, and computer stays cold. Is it the power supply, maybe? How do I get to the power supply, as this does not have a typical desktop footprint?
John Knobloch
Comment by seanmichael6, posted on Jan 08, 2009
Nick Sharp you are a god, but i've tried replacing the capacitor @ PEC19 on my Acer L100 with no luck.
Can you give further spec on the capacitor? I couldn't find a 6.3 volt one but been told the higher voltage one i've installed would do.
Also you say this had "obviously" failed. You talking about capacitor plague?? If so, none of mine seem to show failure at the vents or any leakage of the capacitor gel.
Would appreciate any further help as still live in hope of being able to breath life into my machine.
PS have contacted Acer atthough unit out of warranty who didn't want to know unless i paid for them to inspect it first. Also tried to go back to the supermarket website that i puchased it from to see if i had any recourse, They also didn't want to know unless i first paid for a full technical report showing exact cause of failure! - Thanks Acer!
Comment by Guest, posted on Dec 18, 2008
deosnt power up
Comment by Hermelindo, posted on Dec 02, 2008
I had exactly the same problem I send to analisys they told me the motherboard went dead because (probably) of overheating and to change to motherboard is actually more expensive than a new unit.
To anybody have a defective unit to sell the (working) motherboard?
Comment by seanmichael6, posted on Nov 04, 2008
Surprise surprise i have a sililar problem! machine won't boot when power switch pressed. hard disk light flickers once, and fan comes on but won't boot. Quite happy to take & eject CD's but thats it. tried to unplug & leave & try again, still the same.
Comment by Ray0104, posted on Oct 05, 2008
ThanksMy L100 juat doeant boot now 18 months old over heats , I press the on button the central LED flashes and then thats it, Amazon are selling for £275 is it worth a repair? can I just pull out the hard drive and recover the data onto a new pc?
A repair would be preferable
Comment by hipbone43, posted on Sep 26, 2008
I have the same exact problem. One day, I tried to turn on the computer and nothing. The light on the AC/DC adapter is off, when I unplug from computer and from wall and plug back in to the wall, the light comes on. As soon as I plug into the computer, the AC/DC light goes off and nothing comes on for the computer. Tried a universal AC/DC adapter, the light flickers, sounds like a short on the MB to me. All V meters are good for both AC/DC adapters, must be internal. Purchased May 2007, now useless 16 months later.
Comment by Guest, posted on Sep 23, 2008
I purchased the L100 with the refund from my gateway that was defective from the start (long story). The HD had to be replaced less than a year after purchase. Then 1 year & 2 days after that, total comp failure. I have an extended warranty, but here I am, 3 months after I reported the problem,10 calls to tech support, not fixed yet. Acer doesn't seem to have a new motherboard for it. Was told yesterday it won't be cost effective to fix it, and I will likely get a refund. My last "refund" was tigerdirect credit. Not sure I want to buy from them again after 2 nightmare comps! Any advice for the next comp I buy?
Comment by Guest, posted on Sep 20, 2008
I have the exact same problems , just ove a year old and strated to freeze one day. The wouldn,t power up, local tech solved problem for a while with large fan blowing over it with case top off.Extreme heat coming form hardrive ,Now totally dead Usual acer comment from company.Cost a fortune to fix so bought another computer.
DO NOT BUY THIS HEAP OF JUNK
Going to purchase new motherboard from other sources and try to salvage it to get infor back
Comment by prostar5, posted on Aug 30, 2008
Does not power up. External power supply fine. Suggested reset power button protocol failed. Called tech support, since 17mo old, out of warranty repair requires $449 up front. Second option is replace the suspected motherboard and do an exchange at
Notebook Solutions for $165- 211 depending on which one. Third option is salvage anything usable and move on which might be the best.
Comment by irgle, posted on Aug 19, 2008
Shut down one night - next morning nothing! I am in the UK and Acer want to charge £53.13 just to ship and look at it (with no undertaking what it will cost to fix!) - mine is 17 months old!
Comment by pezanity, posted on Aug 15, 2008
The Acer Aspire L100 is a piece of junk. I had originally purchased the unit to incorporate within my wall unit to handle my multimedia needs geared towards music. I have returned the unit 4 times in the last 18 months due to motherboard failure problems. The motherboard, thermal fans and hard drive have been replaced 3 times.The unit died again August 14th 2008 and will not power on. Acer states that since it is now 6 motnhs our of warranty that they will only fix the problem if I pay. I have since filed a complaint with the Better Business Bureau of Texas where Acer America is located about this defective model.
Comment by jmoney2, posted on Aug 10, 2008
L100 was great 'till it won't start. now has very quiet fan noise, no video, and therefore no response. hard drive is fine. should have known not to get something with totally proprietary replacement parts. am sure other acer products are good, but probably not this one.
Comment by Buteo, posted on Aug 07, 2008
EXACLTY the same problem here. Acer charged me for 300 euro with a new motherboard. I didn't pay so far. Some advise?
Comment by not2akamai, posted on Aug 04, 2008
Same deal. 18 months old. My wife shut it down "to save energy" and it won't come back to life. Power supply is good; 20V at the motherboard. No voltage at the start switch. Acer quoted me a flat rate of $449 to fix.
Comment by Dave Jenk, posted on Jul 31, 2008
Same problem here. Been to the PC repair shop with mine and been told that at least 2 of the capacitors have blown. Sounds like a common problem to me!
Comment by Guest, posted on Jul 26, 2008
Hi EXACTLY the same here. I went to the computer shop and there was an other L100 with the again exectly the same problem. Also absolutly no power. 17 months old now. I didn't find a solution yet...
Comment by falunfixit, posted on Jul 04, 2008
Had my al100 for 16 months. Started acting up like software lockup for past 6 months. Thought it was a Vista problem till this morning when I started it up it locked up when I tried to restart after forcing a shut down it powers up the fan runs no status lights I hear the hdd wind up. I took out the hdd and put on another pc its fine so looks like mb failure. In hindsight I should have seen it coming. Thought highly of Acer till now. Better do a rethink on my opinion.
Comment by Pippu, posted on Jul 02, 2008
Wow. Same thing happened to me... I shut down my Acer L100 on Friday night, and it hasn't come on since. It's just dead. Isn't there anything we can do about this? My Acer is less than 12 months old... it's ridiculous!
Comment by 3607chapel, posted on Jun 27, 2008
Exactly the same thing happened to me - shut down Tuesday evening for the first time in months - just to give the computer a "break"... Thursday evening - nothing, totally dead. Same answer when I called Acer for help. Essentially = too bad that you are 2 months out of warranty, but just send us $449.00 and we'll check it out for you. Never, ever will my company or I buy anything from Acer again...
Comment by Guest, posted on Jun 21, 2008
I have had the same problems, after 13 months and whilst using the computer it popped and shut down. Will not turn on at all, have taken it to a computer repair shop and they have advised that the power supply has overheated and has blown a couple of components on the motherboard and will cost between £110 and £150 to fix the problem. I think a letter to trading standards is needed because it looks as if a lot of people have the same problem.
Comment by jdconnell, posted on Jun 07, 2008
I applied Vista Service Pack 1 this morning and did a warm boot. The system seem to run fine. A storm was coming in so I shut the L100 down and like the others who posted, it will not power up. The external power supply/cord is working but the unit is dead.
Comment by shakybug, posted on May 25, 2008
where do i find a replacement system board for acer apire l100
Comment by goodier, posted on May 16, 2008
Same problem. This happened previously under warranty (eight months old). I sent the computer to Acer and it was returned with a new Main Board. Now, one month out of warranty, it happened again. Acer sent a new power transformer/cord but that was not the problem. They refuse to do anything further. I am trying to get information about obtaining a new Main Board and am awaiting a price and availability to determine if I want to try to do this myself. Acer stated they will make the repairs but will hold $449 on a credit card before starting repairs. It sounds like thirteen months is the crucial timing for breakdowns - get an extended warranty.
Comment by pwlyons, posted on May 07, 2008
Similar problem, I almost never shut it down. Had been using it on Saturday 05/03/08, came back into office and unit was powered down. Could not get it to power back up. 1 month out of warranty.
Comment by Guest, posted on May 05, 2008
Sudden death indeed - my acer just did the same thing to me. Still searching for a solution, but I'm looking at the m-boards batteries and at the switch on the front. They're the only ideas I have at the moment.
