Question about Vacuums
Need replacement part, maroon cover top handle of Z570 cordless
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the brand name and you do have the model # Z570 but I would suggest that you contact your local vac dealer and they should be able to tell you where to get it or they can order it for you, you need to supply the brand name and model # in order to get the part. As an example, you can use the Eureka website as: (if the brand name is Eureka)
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 01, 2008
How do I pop the top off to replace level adjustment lever.
Turn the machine over (with the handle released). Remove the 4 screws (2 on each end of the cover over the brush). Remove the cover. There are 2 screws, deep in the machine (behind drive train wheels) remove the screws. With the machine in the same position, note 2 plastic clips located on either side of the top cover. Release the clips using a slotted screw drive.
Nov 28, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Kirby Generation 3: Having trouble putting plate back on where electrical cord attaches. Ever since the shop put a new cord on for me, I have trouble using release lever for dropping the handle when I...
There are 2 tabs on the bottom front edge of the switch plate which slide under the metal top cover. Make sure these tabs have not gotten bent upward so they will not slide under the top cover. If they are bent, simply pry them open. Also, note that the handle pivot has a sliding latch on it to allow the handle to be fully lowered. To lower the handle flat, push the little knob inward.
May 03, 2011 | Vacuums
Belt is broken
there are 4 tabs, 2 on each side. use a flat head screw driver to pry the top cover away from the bottom the clips are located close to the corners of the vacuum. after you have these clips removed, press the handle release to rotate the head up a little and the top cover will come off. (be careful not to loose your height adjustment button when you take the top off) let me know if you need any further assistance
Apr 08, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
I have a worn clip - the open close clip to secure the adjustable handle in place. I have the new part but, not sure how to fit it. Can you help?
Yes. Remove the handle and cable, then remove the bag compartment cover. At the back of the bag compartment, towards the top, you will see four screws. Ignore the one furthest to the left, and unscrew the other three. That will release the cover at the rear, and expose the clip you want to get at. The clip is held in place by a metal C-clip, which can be levered off with a screwdriver, but be careful not to damage it because you will need it to secure your new clip. when you've got the new clip in place, re-position the cover (not that it clips in at the top first), replace the three screws and the job's done.
I value your feedback, so please remember to rate this response.  Good luck!
Jul 22, 2009 | Sebo X4 Bagged Upright Vacuum
Battery charger broken
CHARGER WONT WORK MEC B5265 CAN I BUY NEW ONE?
Dec 28, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
BISSELPRO HEAT CARPET CLEANER
With the top part of the handle off, lay the handle back and at the top in the middle, there is a catch, just push it in to release it and the front of the handle will come off.
Jul 21, 2008 | Bissell 1699 ProHeat Clear View Upright...
Help
the handle should be down and the top may have a tab on both sides to pry out with screwdriver. lay handle down and turn machine over. look closely around base between cover and there should be a tab to push on and cover comes off.
Jun 07, 2008 | Eureka Vacuums
Handle on kirby ultimate g won't stay upright
Just take the handle off, rermove the 2 screws on the front of the cover, remove the plastic piece on the back of the top, then remove the 2 screws and the top cover will come off. There are 2 screws holding the handle pivot on, remove those. Install the new pivot making sure that it alines with the transmissing on the left side, re-install the 2 screws and make sure they are tight. Then put the rest back together.
May 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vax 4100, how to disassemble for repair
To disassemble a canister vax you first remove 2 screws holding the handle cover. One is just above where the power flex enters the handle, the other is at the mid-point of the top, hidden under the label. Both are small crosshead screws. Before doing attempting this, you need to be competent with working on mains electric wiring, as some of this has to be removed to do all this.
Once the handle covers are removed, the next bit is to gently lever off the speed control knob - it's a tight friction fit, then undo the nut holding it to the handle cover panel. After this undo the mains power connections from the multi-block joiner they go into then remove the 2 screws securing the mains wire. Then undo 2 bolts at each end of the handle going downwards into the main body. At this point the handle can be removed as well as the top body plate. You have to fiddle the electrics and switches through the hole in the top body plate to remove it. Now 3 bolts and a small crosshead screw is all that holds the upper motor section to the lower. Remove these and you can separate the 2 halves which gives you acess to the water pump. This is held in by screws founf underneath the plastic ring at the base of the motor body (around where the small reound blue sponge filter goes). This ring is held in by plastic springy clips. Gently lever round it to get it come off.
That's it. Re-assemble is reverse of all this. Don't disconnect the electrics without drawing pictures or photographing to work out which wire goes to where.
Mar 12, 2008 | Vacuums
How to open case??
I don't know this vacuum personally, but i'll take a stab at is. You're off to a good start prying around. There is most likely a coupld of screws holding things together somewhere. Check around the bottom and sides for holes where phillips screws may be lurking.
Hope this helps. Please rate this accordingly.
Feb 03, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
54 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
