Would like to know the wattage oiutput on my vulcan duel fuel oil heater
I think the question asker wants to know the heat output of the heater measured in Watts so as to get a handle on it by comparing it with an electric heater they may have. Rated HEAT output may be quoted in Btu's (British thermal units), Mj (mega joules) or kW kilowatts (1000 watts) I recently help my brother install a vulcan oil heater which had a maximum output rating of 40,000 Btu.  3,412 Btu's = 1kW so therefore the rated output = 40,000/3412=11.723 kW You need to be careful when calculating  outputs of gas heaters as  these usually quote the maximum value of consumption (in MJ) 3.6Mj =1 kW  A domestic gas heater rated at 36Mj input does not have a heat output (into your room) of 36/3.6 = 10 kW as the efficiency of fuel conversion can vary from as low as around 45-90% subsequently the heat output can be as low as 36/3.6*.45 = 4.5kW or as high as 36/3.6*0.9=9kW in the case of a flueless portable heater which you would not be wise to intall inside due to the nasty gases produced and the fact that a litre of water is also put into the room for each litre of gas burnt.
Posted on Mar 07, 2009
  • 828 Answers
¿ Oil heaters do not generate wattage. On the name plate for the unit it may give you an AMP draw. Multiply Amps times Volts to get wattage use when in operation.
Posted on May 01, 2008
Mum's Vulcan oil heater was serviced.Filter changed. Always hasn't burned all the way to the ends it's standard 1 control knob. Is there a oil/air mix adjustment. Can't find online manual anywhere.
Probably needs burner pot cleaned out, common thing to do.
Its a 40 series oil heater, only had single knob, air adjust is automatically set by internal controls.
where abouts are you.
I have some parts and manuals still
Jul 03, 2017 | Vulcan Heating & Cooling
Do the raidiants in a Vulcan heater need to be replaced regularily?
No requirement to replace, even if broken. If they are all broken or missing then get spares
May 01, 2014 | Vulcan Heating & Cooling
Vulcan oil heater how to remove heating element
Burner pot needs to be removed from heater, for hearers of this vintage, Best advice is to have the burner pot and heater serviced and replace ignition element at same time, I can do this,live in Adelaide. Probably cost $250 inc parts, test run, calibrate.
May 17, 2012 | Vulcan Heating & Cooling
Where can i get heating filter (ceremic?) replacement parts for an old vulcan heater?
Do you know the model heater?
Can you post photo of the filter?
I have some filters for Vulcan oil heaters
Aug 18, 2011 | Vulcan AUW230A Heater
Just installed a vulcan oil heater, but when you start it up it will only burn yellow flames and keeps going out and will smoke, then relight with a bang,
Sounds like you may have the wrong size tip on your oil burner. A yellow flame indicates too much fuel not enough oxygen.
Jun 08, 2011 | Heating & Cooling
Require replacement glass for old vulcan oil heater
Hi ddsalm,
Did you ever recieve an answer to this?
Jun 22, 2010 | Heating & Cooling
Vulcan oil heater won't restart
if it is a two line system the pump should prime its self on a one line system there is a bleeder screw 3/8" on the pump but remember every time the reset is reset the pump could be adding fuel to the burner so make sure it is getting spark you should here it hope this helps also make sure you have fule not water in lines
Jun 08, 2009 | Heating & Cooling
HAVE A gms9/gcs9 GOODMAN DUEL HEATER
if the gauge is stay on 50 then it stuck and you could be out of fuel
Dec 18, 2008 | Goodman GMS90703BXA Heater
Vulcan oil heater
Regarding the wiring on my ancient Vulcan oil heater...I have only just received a wiring diagram (dated January 1969), which I am just about to get stuck in to. I hope that I can follow it (the drawing looks like the last copy of something that's been copied 1,000 times before on one of those old Roneo, wet ink, wind-it-by-hand copiers). The drawing came from a Vulcan agent on the very far side of Adelaide. Here's hoping. Ooroo, John. .
May 27, 2008 | Heating & Cooling
Vulcan Oil Heater
move the collar away from the orifice for a blue flame. too little air causes incomplete combustion so you get the yellow tinging
May 18, 2008 | Heating & Cooling
Heating & Cooling Logo
199 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
