Question about Intermec EasyCoder PC4 Label Printer
Will not print labels
I have a program that requires two printers using a a-b switch. the laser printer is a brother dl2050. my intermec has worked fine for 8 months. now it acts like its printing, (the icon domes on at the bottom of the window, then goes away) but nothing prints, queue clears. now if I turn the switch to the brother the label prints on it(plain paper) and, if I switch the switch to the intermec it will print plain paper stuff. (word, html etc) I've un-installed and re installed printer, and drivers. I even barrowed a working c4 and installed its software, same thing.. the test page prints out on the labels, but labels don't!
    Problem Solver:
  • 6 Answers
You have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
Posted on Aug 15, 2008
Easycoder C4 Printer wont print
See if this can help:
epsfiles.intermec.com/eps.../1-960572-01%20UG%20EC%20C4.pdf
May 26, 2014 | Intermec Easycoder C4 Therm Label Printer...
Printer printer duplicate labels
i have the same issue, this case happened when out of paper or ribbon, while this program and label form works fine with the zebra printer
Oct 18, 2012 | Intermec EasyCoder PM4i Label Printer
How to adjust intermec to print thicker labels
Only user Intermec Labels or they will probably not work.
Feb 20, 2012 | Intermec EasyCoder PC4 Label Printer
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Oct 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
C4 intermec printer
If you're using this printer on a print server then do the following
Turn Printer Off
Disconnect Data Cable
Press & Hold Feed button whilst switching on
Keep Holding Feed Button until test label is complete and light has gone red
Switch Printer off
Reset your Print Server
Plug Data Cable back into printer
Switch Printer on
This should start it printing (unless there are jobs inthe print queue, if there are then they will need to be deleted before printing will commence)
Mar 28, 2008 | Intermec EasyCoder PC4 Label Printer
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec EasyCoder  PC4 Label Printer Logo
410 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
