I am using nokia 2700 classic mobile, some times it shows no sim card available in display. so i switch off my mobile to switch on means it shows Start up phone without simcard?
First try by changing you are mobile battery if you still face this problem means you can remove you are memory card from you are mobile after that if you have anti antivirus in you are pc means scan it.After scanning also if you find this problems means you need to flash your mobile phone.This can be done by the LG service center.Thanks for your question.
you can use *#7370# for format your mobile. ..otherwise you can format by following some simple steps.
first switch off mobile. then press * 3 and call button continiously. By doind that same time switch on the mobile that time you need to press above mensioned keys continiously. '
press on/off (power) switch of ur mobile now remove ur battery and reinstall the battery without releasing the on/off switch. repeat this 3-4 time without releasing on/off switch.
Hi Friend, Please find the below mentioned steps and kindly follow the steps,
1.Switch off the mobile. 2.Remove the sim card,battery and memory card. 3.Hold the switch on button for 20 to 30 secs, 4.After that replace the sim card and the battery. 5.Now switch on the mobile, 6.After it has switched on now replace the memory card.
I sounds like the switch is not making contact relieably. Make sure your key is clean and if that does not work, than the switch inside the console will need to be replaced. Contact Pride Mobility for a technician local to you.
automatic switch off mobile & it lost its phone data(my msg.)date and time
;my mobile setting will change
please send us solution for this
my email id [email protected] .
