Insufficient cooling in my mercedes 300e 1989. When i hook the manifold gauge and turn on the AC, the low side pressure shows ~70psi and high side 200 - 230psi(low side pressure stays constans and high side not to)
  • 828 Answers
1989 year would indicate the system uses the Old CFC R12 refrigerant. 70 PSI equals about 70°F . This is not enough pressure difference to give you any cooling. Sounds like your compressor has bad valves. Replace compressor.
Posted on May 01, 2008
2000 vw Jetta ac not cooling, ac compressor is on, freon level good, with ac manifold gauges high and low side fluctuates from 50-60 psi on low side.
try to throw cool water on the condencer front of the engine radiator and see whether any cool air comes in the car. If so see whether the pressure valve is working okey or not because might the pressure is not sufficient.
Sep 05, 2012 | 2000 Volkswagen Jetta TDI
Forester ac compressor cycles every few seconds but pressure on lp side shows high in gauge
Is it possible you hooked up to the factory service port on the high side instead of the low side port ?
Can you hook up a set of gauges to both high and low ports ?
Jul 27, 2012 | Cars & Trucks
When i turn on the a/c,the compressor does not work
CHECK REFRIGERANT CHARGE. USING A MANIFOLD GAUGE SET. HOOK MANIFOLD GAUGE SET TO LOW PRESSURE PORT AND HIGH PRESSURE SIDE PORT. LOW SIDE PRESSURE SIDE SHOULD HAVE 25 - 36 PSI AND HIGH PRESSURE SIDE SHOULD BE 178 - 237 PSI. IF LOW SIDE PRESSURE SIDE READ BELOW 20 PSI THE LOW PRESSURE SWITCH WILL NOT TURN ON THE AC COMPRESSOR CLUTCH NEED TO ADD LITTLE MORE REFRIGERANT. IF REFRIGERANT LEVEL CORRECT CHECK AC COMPRESSOR FUSE AND RELAY.IF POWER GOING TO AC COMPRESSOR CLUTCH YOUR COMPRESSOR CLUTCH HAS OPEN WINDING. AC COMPRESSOR CLUTCH NEED REPLACING.
Aug 11, 2011 | 1997 Nissan Pathfinder
The compressor is working but it is not blowing cold air. air turn off once in a while. need to turn off motor and restart truck so the air conditioner can restart
YOU MORE LIKELY NEED MORE REFRIGERANT IN SYSTEM SOUND LOW FIRST HOOK A MANIFOLD GAUGE SET CHECK AC LOW PRESSURE SIDE AND HIGH PRESSURE SIDE.LOW PRESSURE SIDE SHOULD BE 34 PSI AND HIGH SIDE SHOULD BE 228 PSI.
Jun 03, 2011 | 2003 Chevrolet Silverado 2500HD
How to add freon to a 1987 Mercedes 190e 4cyl
You need to use a pressure manifold gauge:
http://www.amazon.com/Pit-Bull-CHIMG777-Conditioning-Manifold-Gauge/dp/B000VAQQ3Y/ref=sr_1_3?ie=UTF8&qid=1374522452&sr=8-3&keywords=r22+pressure+gauge
Connect the red hose to the high pressure side located in front of the radiator, connect the blue hose to the low pressure side located in front of the fuse box, there is a thick metallic tube that has a tire-style cap, unscrew that and attach it, purhcase R-12 refrigerant can of at least 1kg, then attach an adapter to the can and connect the yellow hose to this part, open up the flow valve and turn the can upside down while your car is running and the A/C is on.
Check for pressure, the high side should have a high pressure and low side should be as low as possible while the compressor clicks on. Google for the exact pressure numbers as I don't remember.
Just make sure that the AC compressor located at the bottom of the belts is engaged, this is engaged by the correct pressure setting automatically
Mar 16, 2011 | 1987 Mercedes-Benz Mercedes Benz 190 Class
How do i hook my manifold gauges to my residental condensing unit to check pressures
The AC manifold gauges set have the three chambers: the low pressure chamber (left side), utility chamber (middle), and the high pressure chamber (right side).
When technicians connect the HVAC manifold gauge to the air conditioner units, he connects the low pressure side of air conditioner unit to low pressure gauge side.
If he wants to read the pressure in discharge line he connects the high pressure gauge hose to the air conditioner high pressure side.
The utility port (the middle chamber) is a place you connect the hose to vacuum pump, recovery units or add or remove refrigerant from AC units.
Air conditioning gauges is used to measure air conditioner units pressure within closed-system to evaluate or troubleshoot the AC units. Gauges manifold set is the most frequently used item when it comes to refrigerant or pressure.
Air conditioning gauge set allows the HVAC technician to check AC units operating pressures, transfer AC refrigerant, pressure test system, purge the system with nitrogen, and perform other necessary tasks.
The gauges manifold set includes the hoses, the manifold, the valves, the compound gauge (low pressure gauges) and high pressure gauge.
Jul 24, 2010 | Heating & Cooling
Need air cindition recharge, don't have cash to take it someplace, can you help with instructions to do this
YOU NEED A R-134 GAUGE SET TO CHECK LOW PRESSURE SIDE AND HIGH PRESSURE SIDE.YOU ALSO CAN BUY A LITTLE CHEAPER GAUGE TO CHECK YOUR AC LOW BLUE SIDE AND HIGH RED SIDE AT ANY AUTO ZONE OR ADVANCE AUTO PARTS.WHAT YOU DO WHEN YOU GET YOUR GAUGE SET HOOK GAUGE TO LOW PRESSURE SIDE BLUE CAP PORT AND GAUGE TO HIGH SIDE PRESSURE RED CAP PORT.YOU CRANK CAR UP GET IT OPERATING TEMPERATURE.THEN TURN AC ON HIGH COOL LET RUN 3 TO 4 MINUTES.CHECK LOW SIDE GAUGE READING SHOULD BE 28 - 32 PSI. HIGH PRESSURE SIDE GAUGE SHOULD 199 - 228 PSI. THATS NORMAL CHARGE. SEE YOU CANT JUST RECHARGE AC SYSTEM UNTIL YOU CHECK IT FIRST YOU WILL DAMAGE SYSTEM .NOW YOU CAN GO TO AUTO ZONE PARTS BUY A CHARGE CAN WITH GAUGE AND HOSE.ATTACH TO IT.YOU NEED MORE THAN ONE CAN.WARNING MAKE COMPRESSOR IS RUNNING WHEN YOU TURN ON AC .BECAUSE IF COMPRESSOR NOT RUNNING CHECK FUSE AND AC COMPRESSOR RELAY.IF BOTH OKAY.YOU COULD HAVE OPEN CLUTCH COIL A FAULTY LOW PRESSURE SWITCH WILL CAUSE AC NOT TO WORK. IF LOW PRESSURE GAUGE BLUE SIDE PRESSURE IS 28 OR 30 YOU DONT NEED A CHARGE.PROBLEM SOME WHERE ELSE.BE SURE TO WEAR SAFETY GLASSES WHEN WORKING ON AC SYSTEM.
Jun 26, 2010 | 2004 Hyundai Elantra
AC not cooling for 97 Passat TDI
A/c should be charged on the low side while engine is running. Make sure high side valve is turned off. Low side reading should be around 32-35 psi at idle high side should not go above 250. I hope this helps,good luck
Aug 01, 2009 | 1999 Volkswagen Passat
Recharged ac now when i turn it on u can hear the ac sytem try to kick on then stops
It probably is over charged. Hook up a manifold gauge set & check the low & high side pressure when it tries to come on. Low should be 34-40 & high should be no more than 150 psi.
Jul 13, 2009 | 2002 Nissan Sentra
Heating & Cooling Logo
151 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
